R8 GTI SILL Flare Fixings
frendok
Post by frendok »
Hi,
I'm currently in the process of putting my car back together but am unsure of how the lower edge of the sill flare attaches to t5he sill, I can see the clips (DYC10074LOQ) on Rimmer Bros but I'm not sure how they locate as the sill flares were off my car prior to me dismantling.
Would anybody have any advise or even better a picture of how these are fixed/located so I can get them back on.
I know some people have drilled and used self tappers to hold the lower edge but as I've had the sills replaced and painted I don't want to start drilling into them.
Many thanks in Advance :-)
Plodder
Re: R8 GTI SILL Flare Fixings
Post by Plodder »
I believe there were headed pins in the sill flange that slotted into a keyhole slots in the flange on the bottom of the sill flare.
When the sills get repaired you lose the pins.
I have the same problem with my 416 GTi and have yet to come up with a solution that is flexible enough to allow the flares and fixings to be easily removed to allow easy cleaning .
Sadly the flares are still in the spares box.
frendok
Post by frendok »
Hi Plodder,
Thanks for the reply, I'm thinking of bonding the plastic locating clip to the sill panel, then I can at least still remove the sill flares for cleaning periodically, the main issue for me is the lower edge of the sill flare and how this attaches as I did not have a reference point to start with as my sill flares were removed.
Best Regards,
Vinny1979
Post by Vinny1979 »
Do you want a picture of this?
I have my car here with the clips removed
From a longevity perspective I wouldn't refit them they contribute to cill corrosion.
frendok
Post by frendok »
Vinny1979 wrote: Sat Mar 14, 2026 2:18 pm Do you want a picture of this?
Hi Vinny, apologies I totally missed this! I'm guessing by now your sill flare is re-attached but if it is still possible to send a couple of pics of the lower edge and how its fixed to the sill it would be hugely apricated.
frendok
Post by frendok »
Mr Teddy Bear wrote: Thu Jul 02, 2026 9:25 am From a longevity perspective I wouldn't refit them they contribute to cill corrosion.
Thanks Mr Teddy, total agree but I think they need to be on the car so its back to its original spec, I do plan to remove and to clean behind on a regular basis to keep the corrosion away.
Vinny1979
Post by Vinny1979 »
Will do
frendok
Post by frendok »
Vinny1979 wrote: Sat Jul 18, 2026 6:13 amWill do
Thanks Vinny, greatly appreciated :)
