418 td xud engine heater problem
diesel power
my heater goes luke warm when idleing and gets waemer as i drive its not loosing coolant and not overheating ant ideas thanks craig
rover 418 sd and cabrio diesel
richard moss
Are your radiator fans running all the time and over cooling the engine? On a similar note, is the thermostat OK (although if it was stuck open it would normally cool too much when moving).
It's also worth remembering that diesels don't generate as much heat as petrol engines in the first place.
diesel power
