Official Rover Loose Leaf Wksp Manual
Thanks to a conversation at the Bristol Classic I now have in my possession [on behalf of the club] a loose leaf copy of the work shop manual.
This covers the following engines;
1.4 K8
1.4 K16
1.6 S/DOHC
2.0 T16
Engine Management Systems:
PGM FI
MEMS-SPi, MPi
Manual G/Bx 1.4/1.6/2.0
It also covers the body in a lot more detail than Haines goes into
Should Club Members require photo copies of particular sections, then I will copy and post out. You need to have a blue forum name for this needless to say!
Thank you.
214cab
Re: Official Rover Loose Leaf Wksp Manual
Post by 214cab »
I've recently acquired a two volume repair manual and a subsequent supplement volume. Is this the same as whst you guys have got?
JEASPEKE
Post by JEASPEKE »
Hi
That workshop manual sounds excellent, how many pages are in PG MFi section and how many in the 216DOHC section.
Also how do I turn blue to get access
Cheers
John Anfield
Hi,
regarding turning blue you need to pm Tom Pinney and get him to talk to Smithy, she runs the website.
Regarding the manual I will come back on that.
JEASPEKE
Post by JEASPEKE »
Thanks, I have sent Tom a PM ref turning blue, any update on accessing the Manual PMFI section?
Cheers
John
Publication part number AKM 6987 [2nd Edition] Rover Grp 1994 covering 200/400 models from VIN 605482.
Engine Management System PGM-fi
Comprising 19 A4 sides plus a torque, data, tools sht'.
Contents
Description & Operation
Sys' Components S/DOHC
Comp' Loc' S/DOHC
Operation
Adj' Throttle cable
Repairs.
Dist' S/DOHC
TDC sensor DOHC
Cap
Rotor arm
Igniter unit
ignition coil
throttle cable
housing
Resistor Pk, Injectors
Injectors
Resonator
Diaphragm, Dashpot
Fast Idle Control Soleniod Valve
Electronic Air Control Valve
Pressure Regulator
ECU & Idle Mixyure Sensor
Atmospheric Pressure sensor
O2 sensor
Eng Coolant temp' sensor
Manifold Air Pressure Sen'
Intake Air Temp' sen'
Fuel relay
charcoal canister-catalyst
purge control valve-cat'
214 Cab
Volume One = AKM6987 2nd Edition Dated 1994
V2 ditto
cheers
Last edited by Mr Teddy Bear on Sun Oct 06, 2013 10:23 pm, edited 1 time in total.
214cab
Post by 214cab »
Cheers mine are the same but have a third book which is labelled as a supplement and covers revisions for later models - k series etc
g259fsg
Post by g259fsg »
I too have an original Rover WSM which I bought in the early 1990s. The one I have is AKM 6365 (3rd Edition) dated 1991. This was for our 1990 214 GSi.
I use it occasionally, but most often use the Haynes manual as I prefer the photos and there are quite a lot of tips about doing the job. I agree, the Rover manual is better for some of the body assemblies. A looming job is the replacement of the headlining which has perished and come adrift at the back. Haynes is not helpful, saying it is difficult and best to go to the Rover dealer. At least the Rover manual gives a stage by stage list of what you need to do to get the headlining out - takes two pages!
214cab
Post by 214cab »
Thought i'd post this here (perhaps a link could be added to the first post on this thread for others to find it easier.
A downloadable copy of the official Rover Electrical Fault Finding manual - very useful!
