Official Rover Loose Leaf Wksp Manual
Sir Henry
Re: Official Rover Loose Leaf Wksp Manual
Post by Sir Henry »
Does anyone know of a detailed description of the power roof? The linkages on one side of mine have pretty much all come apart. I might be able to fix the problem without any description by comparing it with the other side, but an exploded diagram would help no end. Thanks.
Vehicles currently owned (smallest first)
2002 Peugeot Vivacity 100cc scooter
1979/80 Suzuki 850 Trike Conversion
1995 Rover 216 twin cam (Honda lump) Cabrio
2004 Jag 2.5 X-type AWD Estate (manual)
1992 Dodge Ram 250 Day Van (3.9 V6, now on LPG)
g259fsg
Post by g259fsg »
Do you mean the electric sunroof?
Sir Enery is talking about the power cabby roof I believe. I will have a look later on.
Sir Henry
Post by Sir Henry »
As implied I meant the electric over hydraulic folding cabby roof.
an-drewm
Post by an-drewm »
Was a detailed description of the power roof (Cabrio) found?
The drivers side if mine is all over the place. The seal nearest the boot doesn't seem to be far enough out and so the rear window doesn't close properly. When I looked today the drivers side only had one of the 3 bolts in and that was loose! There seems to be quite a bit of adjustment on the main mounting plate as well as an adjustable tie rod either side but I am getting nowhere with trial and error *laughs*.
Thanks.
Sir Henry
Post by Sir Henry »
Sadly no official description or diagrams have come to light. By a series of kludges, copies (reversed) of the other side and some serious brute force and ignorance I've got the roof working. It's not pretty, but neither are the wet bits inside the average human!
Sorry guys this slipped my mind. I 'm busy with AGM business this week.
an-drewm
Post by an-drewm »
No probs, would be handy if there is something in the manuals covering hood adjustment as trial and error is only resulting in error at the moment :D
Sorry about the delay. Much to my surprise the Cabby Hood is covered in some detail and includes pages on both manual and power hood adjustment.
If you P.M me your postal addresses, then I will arrange to photocopy and post the relevant sheets.
:oops
:horse
Right I've photocopied 13 page's out of the manual and sent by second class post this afternoon.
