Track R8 214 Sprint
Re: Track R8 214 Sprint
Zs 180 is 20 mm rear , what gearbox are you running ?
MG ZR 160 PG1 with 4.2 diff
214 Sprint track car
216 GTi track car
216 GTi DOHC
216 GTi track car
216 GTi DOHC
Did you have any issues fitting that in ? Running a 1.8 with ported head and mem 3 remap on my cabby .
It's got the r65 box in , thinking of changing to pg1 .
No trouble used mounts, gearlinkage, driveshafts from the ZR just had to remove one bracket that was spot welded on the passengers inner wing to mount the PG1 gearbox mount
216 GTi track car
216 GTi DOHC
216 GTi track car
216 GTi DOHC
Cheers that's on the to do list
216 GTi track car
216 GTi DOHC
216 GTi track car
216 GTi DOHC
Went over to Avo Suspension today and picked up a set of these which should help the handling a fair bit (i hope)....
avo by John Quincey, on Flickr
I went for a set of R1's with B&G adjustable top mounts which are the entry level race units with single bump/rebound. I didnt see the point of paying another £1000 for the R2's with Independant bump rebound adjustment as i cant image i would be able to fine tune them enough to get the very best out of them.
avo by John Quincey, on FlickrI went for a set of R1's with B&G adjustable top mounts which are the entry level race units with single bump/rebound. I didnt see the point of paying another £1000 for the R2's with Independant bump rebound adjustment as i cant image i would be able to fine tune them enough to get the very best out of them.
216 GTi track car
216 GTi DOHC
216 GTi track car
216 GTi DOHC
Like the look of them
keep up the great work and can't wait for the feed back on these
216 GTi track car
216 GTi DOHC
216 GTi track car
216 GTi DOHC
The Origina lNom
I 've always found that thicker front ARB gave me better turn in but when you use heavier duty springs it often negates the need but you lose the suspension compliance. I always found that the ZS 19/20mm ARB gave enough control for the road as it seemed to help the turn in.
On the track it may be different.
Last edited by The Origina lNom on Sat Mar 02, 2019 4:55 pm, edited 2 times in total.
