Which things will kill our cars? Common faults?
clayts450
Post by clayts450 »
nickh wrote: Mon Dec 15, 2014 11:35 pm SPI cars seem to be very thin on the ground with regards to fuel system components, unless someone knows of a secret source?
This.
Stepper motor ? Throttle pot ? Non-existent (although thankfully a fellow member had a TPS which he let me have for buttons) - in fact the whole throttle body are now in silly money territory - 80 quid upwards
1992 Rover 214 SLi
1994 Rover 420 SLi
1996 Rover 620 Si Auto
1999 Honda Accord Coupe 2.0i ES
2004 Rover Streetwise S
Discussions with a major UK parts supplier are on-going and I'm now trying to gauge the pent-up demand for some of the 'high priority' items on our list. Such as...
T-series engine mounts - No. 5, 10 and 14 in this diagram
T-series Coolant pipes
No.13 and 14 in this diag.
and No.18/19 in this diag
If new OE-spec parts where to available at sensible aftermarket prices who would be looking to buy parts?
Vinny1979
Post by Vinny1979 »
Lower coolant pipe yes
Better if stainless
The engine mounts tbh you may aswell buy vibratech ones?
£300 for 3
Although you can get away with 2 and use original cam mount so £220
Post by Johnny 216GSi »
Vinny1979 wrote: Tue Jul 02, 2019 5:03 pm Lower coolant pipe yes
Better if stainless
£300 for 3
These ones? https://www.vibra-technics.co.uk/mg_rov ... urbo_92_95
They're labelled road/race. Are they so rigid that you regret fitting them (too much vibration)?? As some people seem to regret fitting the poly K series mounts sometimes...
Cromp85
Post by Cromp85 »
crepello wrote: Sun Oct 12, 2014 11:11 am Door hinges:
Not a problem once you know that they are bushed with a standard size, and a direct replacement is available.
Forgotten where I got them now, but could dig through the chaos and come up with the source if it helps.
Can you remember the size & material of these bushes?
My door hinges need fixing, but i don't know what to look for.
My Rovers to date:
1995 Rover 216 Coupe in Nightfire red
1994 Rover 220GSI in Tahiti blue
2002 MG ZR 105 in Solar red
1995 214i in Nightfire red
Post by ROVER Cabby »
Coupe and Cabby rubber wire/loom grommet tubes are a must too.
Post by 961tat »
Yes rewired mine yestaday and found it rusting under the rubber , another one to look out for if you didn't all ready know . Out with the paint again :laughing2
https://ibb.co/jh4m7GP
OOOFT! :blink
One on my list for sure, I had an idea on how to fix my loom too, if it works i'll share. :D
JEASPEKE
Post by JEASPEKE »
This post reminded me to sort out my spares and box them up, as insurance:
Spare ECU, tested and working
Spare PAS Pump
Two new distributor caps
Two rotor arms
Drive belts for alternator and PAS pump
Engine Oil Filters x 2
Original clutch friction plate, still with some 50% unused friction lining (also as a reference for splines/dia when buying new)
Myriad of switches, relays, bulbs, bits of looms.
Dozens of original bolts, screws, and bits and bobs that have been replaced, but are still worth keeping in a jar.
I am thinking of laying up some ignition coils,
What else would you add to the survival box, ideas welcome
ImageSpares Box
Post by 220 GSi turbo »
I would add a spare steering lock and ignition switch (I think it was discovered in another thread recently that earlier switches are not interchangeable with later ones), brake servo and fuel pump.
Amongst your spare relays, have you got a fuel pump relay? (The brown one).
