Laser Camshaft Locking Tool - Rover K16
tonyinbeds
Post by tonyinbeds »
This camshaft locking device simply slides between the 2 camshaft pulleys on 16 valve twin cam engines.
Any use to anyone?
£3.39
60% off
https://www.eurocarparts.com/p/laser-ca ... 16-LAS2626
Cheers
Tony
1995 Rover 216 16V (Honda Engine D16A6)
Beds/Northants
Re: Laser Camshaft Locking Tool - Rover K16
Should see mine now...*laughs*
50+ gaskets later there’s no anodised paint left on it..*laughs*
Plodder
Post by Plodder »
Does anyone know of a similar tool for the a D16Z4 DOHC engine thats inexpensive or whether this can be used?
I will need to replace my cam belt in the coming year as I want to do it when I do the valve clearances which are well overdue.
Post by JOHNDQ »
Plodder wrote: Mon Jan 31, 2022 10:43 pm Does anyone know of a similar tool for the a D16Z4 DOHC engine thats inexpensive or whether this can be used?
If you mean the D16A9/A8 you put 2 pins though the tops of cylinder 1 cam shaft bearing caps to lock the cams
214 Sprint track car
216 GTi track car
216 GTi DOHC
Post by JOHNDQ »
Good luck getting anything for a Rover from the ECP's Bedford branch :laughing2
216 GTi track car
216 GTi DOHC
Plodder
Post by Plodder »
Well that sounds straightforward.
I guess if I had bothered reading a manual before responding to this post I would have found this out.🤣
Thanks for the info
