961tat wish I had known sooner I would have bought from you but bought one on auction with plug. Just have to ensure what wires to connect to what. I assume I will need a constant live feed that does not light bulb then a live feed from ignition that lights the screen then black I assume will be earth. Perhaps colours may even match what I need.
Thank you
Looking for dash clock 8 pin
Stevie soft top
Re: Looking for dash clock 8 pin
If I remember rightly the wire for the clock side are the same colour so straight forwardStevie soft top wrote: ↑Sun Mar 06, 2022 11:08 am 961tat wish I had known sooner I would have bought from you but bought one on auction with plug. Just have to ensure what wires to connect to what. I assume I will need a constant live feed that does not light bulb then a live feed from ignition that lights the screen then black I assume will be earth. Perhaps colours may even match what I need.
Thank you
Stevie soft top
Thank you , I hope so. *laughs*
Stevie soft top
Just in case it helps someone else the 8 pin socket of my car plugs straight into a 4 pin clock and works no problem, it will only show time , not radio but that did not matter to me as have radio / cd fitted so mine did not show stations any how. For me a 4 pin clock £10 a 8 pin clock £159 used , so no brainier for me.
