You mean cable ties , type of thing or ?
Bleeding hood pump after fitting new one
Stevie soft top
Re: Bleeding hood pump after fitting new one
Yes i do small ones linked together
Stevie soft top
Thank you , one or 2 more thing if possible my black cloth lining just above head cloth is ragged at edges rest is good , I was thinking or renewing the edges by over coving with black material to match using spray glue , but where or how far out should inner materials come too , on each side above door puller there’s a Velcro tape hanging down , should this go around frame work work and attach to inner roof or just hold the materials together without going around frame to stop them sagging a bit as roof opens.
If you know I would be grateful, I was even thinking of using material spray glue to bring the outer edges together so it looks tiderier when I go to open roof you think this would be ok. ( do no harm ) . Sorry about the questions my first go at a rover my last was a Morris.
Stevie.
Stevie.
