94 coupe turbo diagnostic port
Wayno220T
Post by Wayno220T »
If someone has an r8 with the t16 turbo engine could you please show me with a picture where the diagnostic 3 pin connector is in the engine bay, I have a feeling mine is missing as I can't find it anywhere, thanks to anyone who can help.
Re: 94 coupe turbo diagnostic port
It should be hanging about in the area of the fusebox, ECU, ABS modulator and battery.
If you zoom in, you'll see it connected to the T4 by the jumble of red wires in this pic
Dorchester
Post by Dorchester »
I guess that with or without turbo it doesn't make any difference.
My little 94 214 cab has the same diagnostic port (with its twin alarm port) that can connect any diagnostic tool to the 1.9 MEMS ECU.
Personally I'm using TOAF with its app on my Android phone. It works fine even if it's far less powerful than a T4.
Anyway I succeeded in modifying the advance to a better & faster result.
Rover P5B coupe 1968 Arden green & buckskin leather
Wayno220T
Post by Wayno220T »
Thank you very much chaps, I have mems diag and would like to be able to use it. My car is in the garage currently but I'm reasonably certain the diagnostic port is missing, any ideas as to where I'd locate a replacement??
Thanks again for your help with this.
Dorchester
As I've got the diag plug in my 1994 214i cabby I'm pretty sure you've got yours in your 220T coupé.
In my LHD when you're in front of the car it's located at the right hand close to the fuse box and the battery.
You should have two similar ones: the white one you need, and a green one which is for a volumetric alarm.
Dorchester
Wayno220T
Post by Wayno220T »
Fantastic, thanks so much for the pics always makes it easier, when the car is back I shall have a look for it.
