Yes your totally correct drag is definitely not very good for it being a non turbo car and putting out very low torque wasn't ever going to do to well but it's still a day out doing something with it rather than it sitting around and with a group of you it's a good laugh. I've just brought a Quaife ATB diff so I wouldn't mind going back once it's in to see if it makes any difference getting off the line
Track R8 214 Sprint
Re: Track R8 214 Sprint
214 Sprint track car
216 GTi track car
216 GTi DOHC
216 GTi track car
216 GTi DOHC
Finally got a diff sorted for the Rover should be a nice little upgrade got a Quaife QDF28K ATB. Wont be fitting it this month as should finally be doing a trackday once got the rear disc's on.....
2018-09-05_07-56-36 by John Quincey, on Flickr
2018-09-05_07-56-24 by John Quincey, on Flickr
2018-09-05_07-56-24 by John Quincey, on Flickr214 Sprint track car
216 GTi track car
216 GTi DOHC
216 GTi track car
216 GTi DOHC
Finally got round to fitting a pair of MG ZR Orange banded brake reaction bars today....
2018-10-07_06-00-18 by John Quincey, on Flickr
As you can see there a fair bit shorter so hopefully they have added a chunk of castor. Gearing up for trackday this month as long as weather dont get to bad just need to get the rear disc's on, do a oil change and another 4 wheel alignment and finally be ready
Might get round to getting the race seat in too if the welder can fit me in
2018-10-07_06-00-18 by John Quincey, on FlickrAs you can see there a fair bit shorter so hopefully they have added a chunk of castor. Gearing up for trackday this month as long as weather dont get to bad just need to get the rear disc's on, do a oil change and another 4 wheel alignment and finally be ready
216 GTi track car
216 GTi DOHC
216 GTi track car
216 GTi DOHC
Got a bit done on car today as the weather was nice, had the sump off and removed the DVA power baffle to replace with one with oil control flaps....
2018-10-21_07-36-28 by John Quincey, on Flickr
I also finally got the ZS rear trailing arms on with Black Series poly bushes and rear disc's, just need to get a pair of braided hoses for them .....
2018-10-21_07-35-13 by John Quincey, on Flickr
2018-10-21_07-35-43 by John Quincey, on Flickr
I also picked up a set of Streetwise 17" wheels for £50 to try and make a change of the straights a lot of people fit but dont like them. Still the tyre's all had 5mm so they were worth more than what i paid anyway....
2018-10-21_07-36-01 by John Quincey, on Flickr
2018-10-21_07-36-28 by John Quincey, on FlickrI also finally got the ZS rear trailing arms on with Black Series poly bushes and rear disc's, just need to get a pair of braided hoses for them .....
2018-10-21_07-35-43 by John Quincey, on FlickrI also picked up a set of Streetwise 17" wheels for £50 to try and make a change of the straights a lot of people fit but dont like them. Still the tyre's all had 5mm so they were worth more than what i paid anyway....
2018-10-21_07-36-01 by John Quincey, on Flickr214 Sprint track car
216 GTi track car
216 GTi DOHC
216 GTi track car
216 GTi DOHC
Well guys wish me luck ive finally booked onto a last minute trackday this coming Monday at Bedford Autodrome
Im hoping the weather holds up as other than than normal road tyre's i only have a set of Dunlop spec MG trophy class A slicks
Not to sure how its going to go could have done with getting the race seat in and the suspension sorted really but should still be a fun day will just have to slow up in corners a bit i think
216 GTi track car
216 GTi DOHC
216 GTi track car
216 GTi DOHC
All ready for tomorrows trackday thought i would put a picture up in case its the last time its since in one piece
Shes all loaded up with the slicks/tools etc, a quick wash and £100 of V-Power (full tank and jerry can) later.....
2018-11-18_07-39-02 by John Quincey, on Flickr
2018-11-18_07-39-19 by John Quincey, on Flickr
Had a good day on car today, went through it front to back, replaced engine/gearbox oil and the brake fluid, checked everything was tight etc. Also redone the wheel alignment set the rear too -2.5 degrees camber, toe +.5 per side so see how iit goes.
2018-11-18_07-39-19 by John Quincey, on FlickrHad a good day on car today, went through it front to back, replaced engine/gearbox oil and the brake fluid, checked everything was tight etc. Also redone the wheel alignment set the rear too -2.5 degrees camber, toe +.5 per side so see how iit goes.
216 GTi track car
216 GTi DOHC
216 GTi track car
216 GTi DOHC
Well first trackday is over and pleased to say still no problems to report. Struggled with the car in terms of handling was a bit of a dog to get turned in and hold the line due mainly i think the amount of body roll, the rear end was fairly loose too but in fairness the car is still not on coilovers and still a fair way from any finished project. All in all tho i came back with a feel for the car and the many things i need to improve but i was quite surprised how far off the ZR's pace it was.
[urlhttp://www.youtube.com/watch?v=EAYbg8viYpk&t=31s][/url]
216 GTi track car
216 GTi DOHC
216 GTi track car
216 GTi DOHC
Is the ZS 180 not 19mm? I could be wrong may be 18mm
I've been looking at a kit for the civic and Integra that comes with a brace to preposition the roll bar to use a 24mm bar as it was more turning in that was problem so that would suggest needing a thinner front bar. Think will get the coil overs on first so can get ride height/from camber sorted and see where we are then
216 GTi track car
216 GTi DOHC
216 GTi track car
216 GTi DOHC
A few pictures from the trackday.....
IMG_20181119_121455~2 by John Quincey, on Flickr
IMG_20181119_160818~2 by John Quincey, on Flickr
95F_4013 by John Quincey, on Flickr
95F_4061 by John Quincey, on Flickr
95F_4531 by John Quincey, on Flickr
95F_4531 by John Quincey, on Flickr214 Sprint track car
216 GTi track car
216 GTi DOHC
216 GTi track car
216 GTi DOHC
