Page 12 of 19
Re: Track R8 214 Sprint
Posted: Tue Sep 04, 2018 6:52 am
by JOHNDQ
Vulgalour wrote: Mon Sep 03, 2018 11:50 pm That's respectable enough. Surprising that you took it to drag, up until now I thought it was much more a track focused car where it would likely perform quite well.
Yes your totally correct drag is definitely not very good for it being a non turbo car and putting out very low torque wasn't ever going to do to well but it's still a day out doing something with it rather than it sitting around and with a group of you it's a good laugh. I've just brought a Quaife ATB diff so I wouldn't mind going back once it's in to see if it makes any difference getting off the line
Posted: Wed Sep 05, 2018 7:07 pm
by JOHNDQ
Finally got a diff sorted for the Rover should be a nice little upgrade got a Quaife QDF28K ATB. Wont be fitting it this month as should finally be doing a trackday once got the rear disc's on.....
Image2018-09-05_07-56-36 by John Quincey, on Flickr
Image2018-09-05_07-56-24 by John Quincey, on Flickr
Posted: Sun Oct 07, 2018 6:50 pm
by JOHNDQ
Finally got round to fitting a pair of MG ZR Orange banded brake reaction bars today....
Image2018-10-07_06-00-18 by John Quincey, on Flickr
As you can see there a fair bit shorter so hopefully they have added a chunk of castor. Gearing up for trackday this month as long as weather dont get to bad just need to get the rear disc's on, do a oil change and another 4 wheel alignment and finally be ready :o Might get round to getting the race seat in too if the welder can fit me in :*laughing my fat rear end off*
Posted: Sun Oct 21, 2018 6:51 pm
by JOHNDQ
Got a bit done on car today as the weather was nice, had the sump off and removed the DVA power baffle to replace with one with oil control flaps....
Image2018-10-21_07-36-28 by John Quincey, on Flickr
I also finally got the ZS rear trailing arms on with Black Series poly bushes and rear disc's, just need to get a pair of braided hoses for them .....
Image2018-10-21_07-35-13 by John Quincey, on Flickr
Image2018-10-21_07-35-43 by John Quincey, on Flickr
I also picked up a set of Streetwise 17" wheels for £50 to try and make a change of the straights a lot of people fit but dont like them. Still the tyre's all had 5mm so they were worth more than what i paid anyway....
Image2018-10-21_07-36-01 by John Quincey, on Flickr
Posted: Sat Nov 17, 2018 6:14 pm
by JOHNDQ
Well guys wish me luck ive finally booked onto a last minute trackday this coming Monday at Bedford Autodrome :laughing2 Im hoping the weather holds up as other than than normal road tyre's i only have a set of Dunlop spec MG trophy class A slicks :blushing Not to sure how its going to go could have done with getting the race seat in and the suspension sorted really but should still be a fun day will just have to slow up in corners a bit i think :rolleyes
Posted: Sun Nov 18, 2018 7:56 pm
by JOHNDQ
All ready for tomorrows trackday thought i would put a picture up in case its the last time its since in one piece :laughing2
Shes all loaded up with the slicks/tools etc, a quick wash and £100 of V-Power (full tank and jerry can) later.....
Image2018-11-18_07-39-02 by John Quincey, on Flickr
Image2018-11-18_07-39-19 by John Quincey, on Flickr
Had a good day on car today, went through it front to back, replaced engine/gearbox oil and the brake fluid, checked everything was tight etc. Also redone the wheel alignment set the rear too -2.5 degrees camber, toe +.5 per side so see how iit goes.
Posted: Mon Nov 19, 2018 10:00 pm
by JOHNDQ
Well first trackday is over and pleased to say still no problems to report. Struggled with the car in terms of handling was a bit of a dog to get turned in and hold the line due mainly i think the amount of body roll, the rear end was fairly loose too but in fairness the car is still not on coilovers and still a fair way from any finished project. All in all tho i came back with a feel for the car and the many things i need to improve but i was quite surprised how far off the ZR's pace it was.
[urlhttp://www.youtube.com/watch?v=EAYbg8viYpk&t=31s][/url]
Posted: Tue Nov 20, 2018 7:08 am
Upgrading to the turbo 19mm rear ARB might also help.
https://rimmerbros.com/Item--i-RGB100490
Posted: Tue Nov 20, 2018 7:56 am
by JOHNDQ
Is the ZS 180 not 19mm? I could be wrong may be 18mm :laughing2 I've been looking at a kit for the civic and Integra that comes with a brace to preposition the roll bar to use a 24mm bar as it was more turning in that was problem so that would suggest needing a thinner front bar. Think will get the coil overs on first so can get ride height/from camber sorted and see where we are then
Posted: Wed Nov 21, 2018 8:11 pm
by JOHNDQ
A few pictures from the trackday.....
ImageIMG_20181119_121455~2 by John Quincey, on Flickr
ImageIMG_20181119_160818~2 by John Quincey, on Flickr
Image95F_4013 by John Quincey, on Flickr
Image95F_4061 by John Quincey, on Flickr
Image95F_4531 by John Quincey, on Flickr
