Rover 220 Coupe Turbo Ex-Dunlop Racer
Re: Rover 220 Coupe Turbo Ex-Dunlop Racer
I used the PCI trailing arm bearing on mine. Best mod you can do only thing was since it's offset from centre to allow the arm to be level on lowered cars to have to push the floor up slightly or the arms hits
214 Sprint track car
216 GTi track car
216 GTi DOHC
216 GTi track car
216 GTi DOHC
Hey John, I’m using NKG 6’s at the moment.
Rover 220 Coupe Turbo Racer
You brought theses bearings to my attention John on your track car
So a quick update on the racer,
Not much has happened since the gearbox swap really, mainly due to other car related issues which have taken up my time.
Pulled the racer outside the garage over Christmas along with the FDH so I could give the garage a good clean.
I let the car get up to temperature and allowed the various fluids to circulate.
I replaced my daily car earlier this year with something that has decent towing capacity. Over Christmas, I've just fitted a tow bar + electrics which has been a fundamental issue of mine having a non-road legal race car!
The aim is to buy a trailer later on this year so I can actually transport it places and to also carry on with the remaining jobs.
- New rear discs & pads
- New Roversport front discs & pads
- Full geometry setup for race application,
- New Race/track tyres all round
- Fire extinguisher system
- Race battery system
Then a few small jobs such as wiring up the fan override switch, install some mechanical gauges for the engine and ideally a passenger seat.
Thanks for looking
Thanks for looking
Is that all? You must be slipping!
And here I am wondering how I’ll get on changing the coolant on 200 Bubble.
Have you managed any progress on the car this year?
Hey Plodder,
Unfortunately very little progress for a while now. I had the opportunity to go on a European road trip back in May in my other coupe, so I spent a good amount of time earlier this year getting the car sorted for the trip.
After Christmas, I plan on picking things back up with the race car and hopefully making some progress!
That’s great to hear!
Was a bit worried that the time and cost of this amazing project had taken its toll and you’d had to selve it.
Did you take the coupe round the Nurburgring?
Thomas Loveridge
Looking forward to reading more of your project! It's been inspiring seeing your photos and referencing what I could do to my car! (Not making it completely race spec, more just oem+ and some improvements)James3990 wrote: ↑Sun Oct 13, 2024 12:26 pmHey Plodder,
Thomas Loveridge - New Zealand
1994 Rover 220 Turbo
2001 Rover 75 2.5L Connoisseur
Thanks Thomas!
Amazing how time flys, it’s been a good 2 years I recon since I’ve provided a decent update so it’s well overdue.
As expected, 2025 has been busy due to our main bathroom needing refurbishment (carried out by myself), family holiday, getting Married and then honeymoon.
Getting my priorities right
it was finally time to get back into the swing of things with the Coupe.
With prices now starting to drop again post COVID, I picked up a twin axle Brian James Trailer.
Moving back into the coupe, I realised last year the remote oil cooler wasn’t working effectively due to lack of circulation therefore I needed to get the Roversport modification done which meant removing the oil pump from the engine:
Andy Cowan modified my oil pump, removing the OEM restrictor and completely blocking off this oil gallery which forces all the oil to go round the oil cooler. It’s not thermostatically controlled like what you would do on a modern car, but I’m following the Rover Sport specification.
Andy also helped me source new AN adaptors and washers.
All reassembled with new oil pump gasket and oil filter -Unipart Filters supplied by Tom on the Ropes!
Once completing this task, I started the car up and I had a major oil leak coming from one of the braided oil lines where the stainless steel mesh goes inside the AN fitting.
It's happened before and its all down to the angle of the pipe (trying not to position it under any kind of stress), but its ultimately a weak/failing seal.
I was also fed up with being stabbed and stratched with these 30 year old braided lines fraying, so I decided to replace both pipes with new modern material and also new HEL fittings all round.
Decided to add some heat sleeves too for extra protection.
I did buy a special spanner and vice clamp for AN fittings, but it was still very difficult not to scratch these new fittings.
Turned out to be a bigger job than I realised, very fidley and time consuming but it’s all back together now, engine running up to temp and no leaks!
I’ve got some more jobs planned over the Christmas break, Thanks for looking.
