Track R8 214 Sprint
Re: Track R8 214 Sprint
JOHNDQ wrote: Mon Oct 28, 2019 9:47 pm
That being said brings a few good points, looks better and i can set the car lower but the on the negative side means i cant run the big brake kit so im down to ZR160 282mm discs and calipers :scared Im also going to have to use the 216 GTI wheels (which are heavier than the 17's) because the Turbo wheels rub on the 160 brake caliper carrier. Back on track next month with this set up and stiffer coil springs for a bit of test time to see what happens :tt2
You could also go 16” on hairpins or 17” on addendums
JOHNDQ
Post by JOHNDQ »
1234dist wrote: Tue Oct 29, 2019 7:32 am
I could prob get away with 16's cant image the scrutineers would know the R8 didnt came with those sizes wheels as its not a Rover series :laughing2 but the car was too high on 17's. To be fair tho the races are only 20 mins so with the race pads should hold up ok
214 Sprint track car
216 GTi track car
216 GTi DOHC
Its aa stock wheel mr scrutineer just google it,
Like i did
JOHNDQ
Post by JOHNDQ »
Can finally get on with the car again now xmas and new year are out of the way. Replaced all the seals, pistons, sliders etc for the 160 brakes and gave them a coat of yellow. Not a lot of space under the 15's tho....
ImageIMG_20191229_160115~2 by John Quincey, on Flickr
ImageIMG_20191229_160021_3~2 by John Quincey, on Flickr
ImageIMG_20191229_160053_3~2 by John Quincey, on Flickr
ImageIMG_20191229_160037_3~2 by John Quincey, on Flickr
216 GTi track car
216 GTi DOHC
Jamesridgway1994
Post by Jamesridgway1994 »
What ever you do ffs don't put any balance weights on the inside on the front will ya 😲 *laughs*
JOHNDQ
Post by JOHNDQ »
Jamesridgway1994 wrote: Thu Jan 09, 2020 7:48 pm What ever you do ffs don't put any balance weights on the inside on the front will ya 😲 *laughs*
Only ever put weights on the inside edge as they sometimes come off on track
216 GTi track car
216 GTi DOHC
Jamesridgway1994
I thought the zr 160 /sz 180 callipers wouldn't fit under 15" s? Did you have any clearance issues? Looks very tight!
JOHNDQ
Post by JOHNDQ »
Jamesridgway1994 wrote: Thu Jan 09, 2020 8:36 pm I thought the zr 160 /sz 180 callipers wouldn't fit under 15" s? Did you have any clearance issues? Looks very tight!
No none at all not using any spares or anything either.
216 GTi track car
216 GTi DOHC
Jamesridgway1994
Got 17"' on ATM but thinking of dropping a size so im looking for a set
15 in ?
