OH 3 door 216 GTi's are like buses it seems
Re: OH 3 door 216 GTi's are like buses it seems
i do have a company that may be able to fix that but i couldn't tell you how much it would cost as my customers usually say just source another engine
JOHNDQ wrote: Tue Mar 30, 2021 9:44 pm Little update on the GTI. After one week of socking the pistons in diesel she still refused to turn :cursing so i had no option to remove the head to see what was going on and was greeted with this :o
ImageIMG-20210330-WA0003 by John Quincey, on Flickr
So after a another few days in diesel, a block of wood and i big hammer she finally when crack and started to move :scared After removing pistons 2 and 3 which here completely rusted with all the rings stuck i took them to work and a day in the cleaner they came up like new and with a set of unstuck piston rings
ImageIMG-20210330-WA0005 by John Quincey, on Flickr
Unfortunately the same wasnt to be say for cylinder bore 3 :bored After a clean up and a hone she was just to far gone to repair
ImageIMG-20210330-WA0004 by John Quincey, on Flickr
As you see it wouldnt even be worth getting a over sized piston as the block has very bad corrosion which is a shame as its the original engine fitted at factory :sad
Anyway for the sake of a £15 headgasket im just putting it back together for now so i can move it about while i get a engine sorted as 3 dead R8's on drive is to much :laughing2
ImageIMG-20210330-WA0002 by John Quincey, on Flickr
Shame are you sure it not worth a rebore and block facing ? Were do you get you honda head gasket and parts from anywhere special will be need one soon :wink3
JOHNDQ
Post by JOHNDQ »
RoverRevival wrote: Wed Mar 31, 2021 6:54 am i do have a company that may be able to fix that but i couldn't tell you how much it would cost as my customers usually say just source another engine
Cheers I'll bear that in mind mate I do have another block spare tho bit was hoping to keep it for the cup car
214 Sprint track car
216 GTi track car
216 GTi DOHC
JOHNDQ
Post by JOHNDQ »
961tat wrote: Wed Mar 31, 2021 7:39 pm
If it wasnt for all the corrosion around the water jacket I might have considered it but it is really bad and probably only 1/4 of the original thickness in some places
216 GTi track car
216 GTi DOHC
JOHNDQ
Post by JOHNDQ »
Ok guys had a change of plan, since this car will be going up for sale and im not the kind of person to sell someone a duff car ive decided to bin the original engine and use the unit from the red GTi after a little refresh....
ImageIMG-20210508-WA0026 by John Quincey, on Flickr
First off was to open the engine up and get everything cleaned and checked....
ImageIMG-20210508-WA0023 by John Quincey, on Flickr
ImageIMG-20210508-WA0033 by John Quincey, on Flickr
New sent of GLYCO bearings....
ImageIMG-20210508-WA0032 by John Quincey, on Flickr
Pistons all fitted....
ImageIMG-20210508-WA0027 by John Quincey, on Flickr
ImageIMG-20210508-WA0028 by John Quincey, on Flickr
Bottom end being built up....
ImageIMG-20210508-WA0031 by John Quincey, on Flickr
ImageIMG-20210508-WA0030 by John Quincey, on Flickr
ImageIMG-20210508-WA0029 by John Quincey, on Flickr
Now onto the top half....
ImageIMG-20210508-WA0024 by John Quincey, on Flickr
All assembled all valve clearances adjusted....
ImageIMG-20210508-WA0034 by John Quincey, on Flickr
Finally to fit into the car and im pleased to say shes all up and running like a dream again....
ImageIMG-20210508-WA0025 by John Quincey, on Flickr
Next is a good going over to her ready to go on the road for June 1st
216 GTi track car
216 GTi DOHC
JOHNDQ
Post by JOHNDQ »
Gti is finally ready for the MOT :D hoping to get it done is week so can get her up for sale....
Got the brakes stripped, hot washed, cleaned and resealed, painted and i also replaced the disc's and pads all round just to be safe.....
ImageIMG-20210606-WA0001 by John Quincey, on Flickr
ImageIMG-20210606-WA0005 by John Quincey, on Flickr
ImageIMG-20210606-WA0003 by John Quincey, on Flickr
ImageIMG-20210606-WA0002 by John Quincey, on Flickr
I also fitted a set of lowering springs as lets be honest no one wants a GTi that has the same ride height as a bus, nothing to much just 30mm :laughing2 .....
ImageIMG-20210606-WA0004 by John Quincey, on Flickr
216 GTi track car
216 GTi DOHC
Post by richard moss »
That looks rather smart. The green really suits the shape
JOHNDQ
Post by JOHNDQ »
Many thanks :)
216 GTi track car
216 GTi DOHC
JOHNDQ
Post by JOHNDQ »
Well finally the GTi is finished and sailed through her first MOT since 2001 :D plan is to use her now until end of July while i sort out a few cosmetic things (painting cam cover etc etc) then i will be putting her for sale for someone else to enjoy....
ImageIMG_20210614_204059_4~2 by John Quincey, on Flickr
ImageIMG_20210614_204015_2~2 by John Quincey, on Flickr
ImageIMG_20210615_184639_158 by John Quincey, on Flickr
216 GTi track car
216 GTi DOHC
henryiett
Post by henryiett »
Congrats another one on the road again
Rover 214si 1990
