The 'K series' engine says it all about Rover
mrsimon
Post by mrsimon »
I seem to read the same head gasket failure problem related to this engine whether it's the first or last one ever made.
In all those years, how come it wasn't fixed and made more reliable? On paper, it borders on purposeful gross incompetence. :S
How do you enthusiasts and experts see it?
RR Evoque SE 4x4
Renault Captur 90BHP
Previous Rovers:
Rover 45 V6
Rover 220 coupe 1995
Rover 25 2L D. Rover 45 V6 2001 Sold
3 Scooters = Daily drives in Barcelona
Today is the first day of the rest of your life. :wink3
Re: The 'K series' engine says it all about Rover
The latter years the k-series became the n-series working in harmony with lotus engineers and this is where the uprated gasket, oil rails and the prt system (which is still a weak point).
Numptey
Post by Numptey »
I would imagine it was not an issue until a few years after they had sold a few cars and by the time they realised they went bang
Where to start? The original K Series design intent was for a small light weight engine with class leading power and torque characteristics.
The original design was funded by HMG during negotiations between British Leyland and Margret Thatcher and Norman Tebbit SoS for Trade & Industry. The engine was meant for a new generation of small utilitarian car's following in the footsteps of the Moggy Minor and Mini. It was never envisaged as a 1800 cc engine pulling a medium size 4x4 vehicle.
The original engine is a wet liner block, incorporating a sandwich design of cylinder head/block/crankcase assy. This means that the cylinder head bolts go through the engine and attach to the main journal caps. Thus the crankshaft must not be turned with the head removed.
The main weakness with the earlier version of the engine imo is the plastic inlet manifold and thermostat housing. These fitments make the engine intolerant to overheating. Any aluminium alloy engine will start to overheat if the coolant isn't regularly changed, because of the corrosion properties of the ally' block, in comparison to cast iron for example.
The older single point injection version of the 1.4 K Series incorporated a separate filler neck for the cooling system. This eliminated large air pockets in the coolant rail running behind the cylinder head to the thermostat 'housing on refill. Later M.P.S engines deleted both the filler neck and a drain tap in the radiator.
This makes draining, refilling and bleeding the system very much a time consuming complex job, compared to other designs. The location of the bleed screw should be noted and used otherwise the thermostat won't see liquid and sit in front of a air pocket. A rapidly rising temp' gauge at tickover once warm is symptomatic of air in the system.
In my experience once bled properly the engine performs well warming up quickly and coming off choke reducing cold running and associated engine wear.
The larger 1600 and 1800 K Series involved a redesign of the engine the steel liners supported at the bottom of the block only. This became known as a damp liner or open topped block engine. This is the version that gained the K Series it's reputation for unreliability through head gasket failure. Some one else can continue the story from here.
:bored
Post by ROVER Cabby »
Its just one of them engines that required a bit more car, as you said once you get the head
gasket upgraded and you monitor the cooling system it should never be and issue but the HG
is not always the culprit, on my 25 and on the Cabby it was the Water Pump that failed.
mrsimon
Post by mrsimon »
ROVER-25X wrote:Its just one of them engines that required a bit more car, as you said once you get the head
So many years on the market and never sorted. Says it all about Rover then doesn't it?
Very disappointing. :bored
RR Evoque SE 4x4
Previous Rovers:
Rover 45 V6
no says a lot about tata, bmw ect.....
Nah leave it alone, people will still buy it. :slapme
prepace
Post by prepace »
It's always an interesting debate when HGF and the K series engine are discussed, just to keep it balanced its worth remembering that numerous other marques also suffer from HGF if the car/engine isn't maintained all that well.
'94 R8 214 SEi
'98 618iS
i've never had one go on me. I have bought (alot) that have but its a 4hr job including skim so why worry.
Exactally and because it is such a common fault it is cheap to do, why you say ?
Well as dist says, 'Above all, its a ROVER, and some idiot will buy one' or in our case still
buying them since 2002 *laughs*. :laughing2
