R8SRGR8 wrote: ↑Tue Nov 26, 2019 9:26 pm
Has anyone any ideas please. The car has done a little over 67000 miles.
You could also try a Terra Clean - find a garage near you that does it. It completely decokes your engine and generally helps older cars pass emissions tests. If you've done your fair share of lower-speed driving around town and in plenty of traffic rather than regularly taking the car on the motorway and putting your foot down, then the engine could be suffering from this problem. I've had one done on my car (at the time a 23-year old 216) and it certainly got rid of tell-tale flat spots during modest acceleration. My car was already passing its emissions test, but the figures got better after the clean. It cleans the entire fuel path from the fuel rail, including the injectors and their basket filters besides actually decoking the engine. They take the petrol pump fuse out of your car, then hook up their ultra-clean fuelling machine to your fuel rail and start and run the car a few times, letting it rest in between - whole thing takes 1-2 hours.
Check out the website here:
https://www.terraclean.co.uk/
And no I'm not an agent for Terraclean. But if I had a car that had everything done that needed to be done and it still wasn't passing its emissions tests, I'd have it Terracleaned. Claims that this is "snake oil" are, as far as I'm concerned, invalid. Every "magic fluid" is snake oil if you're trying it before you've tried everything else - but if you've got to the end of the list and you're still not getting the emissions or performance you expect, then it is absolutely worth a go. Read how the project came about - the Canadian government commissioned research to create a zero-emissions fuel for combustion-engine cars. They succeeded but realised the fuel would be too expensive to make and sell. They noticed that the fuel had a decoking effect because they were running old cars on it during their extensive testing. So they repackaged the research into a global decoking service. It's absolutely legit and backed by several years of research effort.
