This camshaft locking device simply slides between the 2 camshaft pulleys on 16 valve twin cam engines.
Any use to anyone?
£3.39
60% off
https://www.eurocarparts.com/p/laser-ca ... 16-LAS2626
Laser Camshaft Locking Tool - Rover K16
tonyinbeds
Cheers
Tony
1995 Rover 216 16V (Honda Engine D16A6)
Beds/Northants
Tony
Beds/Northants
Re: Laser Camshaft Locking Tool - Rover K16
Should see mine now...*laughs*
50+ gaskets later there’s no anodised paint left on it..*laughs*
Does anyone know of a similar tool for the a D16Z4 DOHC engine thats inexpensive or whether this can be used?
I will need to replace my cam belt in the coming year as I want to do it when I do the valve clearances which are well overdue.
If you mean the D16A9/A8 you put 2 pins though the tops of cylinder 1 cam shaft bearing caps to lock the cams
214 Sprint track car
216 GTi track car
216 GTi DOHC
216 GTi track car
216 GTi DOHC
Good luck getting anything for a Rover from the ECP's Bedford branch
216 GTi track car
216 GTi DOHC
216 GTi track car
216 GTi DOHC
Well that sounds straightforward.
I guess if I had bothered reading a manual before responding to this post I would have found this out.
Thanks for the info
Thanks for the info
