twin cam head on single cam engine?
jiminwatford
Post by jiminwatford »
bit of pie in the sky tought, but how easy is it?
if its as simple as, then i might just 'chuck' it on :?
Post by E_T_V »
Which engine is it?
jiminwatford
ah sorry,
D16 (1993 216 GSI)
James
tomcat216
Post by tomcat216 »
Nope it wont sorry. A D16A8 head will not fit on a D16Y7 block. Nice thought though, I considered doing it to my old Coupe. If you can find a whole engine then apparently that is just an easy swap over. A day at the very most.
Mark
'98 Tahiti 216SE Coupe
'99 Charcoal 420SLDi
'96 Silver BMW 525td
'93 Ford Mondeo 1.8LX
'93 Dulux Yellow 216 Coupe - RIP
Subcat001
Post by Subcat001 »
D15b & D16Z6 sohc VTEC heads will fit. Its a conversion called minime and you can read more about it here: http://www.hondacivicforum.com/m_45390/tm.htm.
Please bear in mind this is only a sohc VTEC head and will only yeild similar power to a D16A8/9 DOHC engine.
HTH
James
255.5bhp & 256.1lbs/ft
