Streetwise wheelarch mouldings
Posted: Tue Nov 07, 2023 12:16 pm
by Bean66
Hi All
My Streetwise seems to have rusty wings, so normal R25 then :D
But to get a proper look and sort out in need to get the wheelarch mouldings off.
Now from reading the limited amount on the WWW I think they are held on by some plastic trim clips and double sided sticky pads.
So is it just a case of giving them a good yank to get them off or is there a specific way of doing that.
I don’t want to do wrong and bust a load of clips made from unobtainium :mad
Cheers Bean
Re: Streetwise wheelarch mouldings
Posted: Mon Jun 03, 2024 4:35 pm
by Bean66
Hi All
Did a bit more reading round on this and most thoughts were they just pull off, carefully.
Well i recently got the front pass wing one off and yep the rust is pretty bad so i'll need to sort that, not sure if its new wings or try to sort the old one as their is no visible rust, its all behind the arch.
But the main issue now is I bust three of the clips getting the arch trim off :cursing and can't seem to find the exact right ones.
So the question is where can i get some new ones from or what clips has anyone used that are not quiet right but have done the job successfully.
Hopefully someone got some idea as i'm currently driving around with only three arch trrim.
Cheers Bean
Posted: Tue Jun 04, 2024 7:33 pm
by 220 GSi turbo
Can you post a photo of the clips?
There is always a possibility the clip will be shared with an entirely different piece of trim on another MGR model!
Posted: Thu Jun 06, 2024 1:23 am
by Bean66
Hi All
TBH I’d expected many to have had to take off the arches, prob due to rust, and broken many clips so was hopeful someone would knw the clip and a source.
But I’ve taken a pic as suggested by GSi, as below.
So hopefully someone know of a source.
PS thats one of the unbroken ones, *laughs*.
Cheers Bean
Posted: Thu Jun 06, 2024 9:31 pm
by 220 GSi turbo
That looks quite similar to a lot of clips that are used to retain door cards. What are the various dimensions of it (diameters of the two circular parts and also the overall length)? And what diameter is the hole in the wing?
Posted: Fri Jun 07, 2024 10:15 pm
by Paul_1978_yorks
Howard (RIP) used to swear by a company called Bresco for clips like this.
Posted: Sat Jun 08, 2024 11:29 am
by Bean66
Hi All
I'd not heard of Breso but found their website and going to message them.
Just slightly surprised that someone else on the forum has had to change these clips and hadn't found originals or an alternative.
Oh well maybe tahst me :*laughs*: :*laughs*:
Cheers Bean
Posted: Wed Jun 12, 2024 9:06 pm
by Bean66
Hi All
Well now found the part number EKM100270.
So to help if anyone else does a search Streetwise Wheelarch moulding clips part number is EKM100270
Rimmers do them, but i think i'll pass buying from them as at £2.58 PER CLIP PLUS delivery they ate taking the pi55.
So Ebay here we come.
Cheers Bean
