Timing belt change
neil601
Timing belt change
Post by neil601 »
Hi everyone I’m about to tackle my first ever timing belt and water pump change on my 216 SLI - Honda SOHC engine. Any tips for a novice to avoid problems and are there any special tools I need ?
Neil
Re: Timing belt change
The crank pulley bolt is very tight, you need either a very powerful impact gun or a 4 ft plus long breaker bar because you will need an impact socket + extension. It's r/h thread and Japanese engines run backwards so that's anti clockwise looking at the crankshaft pulley.
You need a tool to lock the flywheel to torque it up.
Note you need to remove the engine mount & support the engine/gearbox ass'y.
Try and buy Cambelt kit that includes the spring + waterpump.
It's not a easy job so not for a beginner, if you lack the appropriate tools it might be a better idea to give the job to a Rover trained mechanic if you know of one?
neil601
Post by neil601 »
Thanks for that Teddy, I think I will get a mobile mechanic in. When you mention engine mounts and supporting the engine, etc, that’s beyond me. You have saved me problems so thank you mate
