unstable idle
Re: unstable idle
the problem that i find is the o2 sensor have slow responce.goes from open to close loop but the ecu dont use it at the time done read it as active.when i start the car goes ok. if i turn off the car and start again have very little unstable idle and lose power. after a while when the 02 is activated (i guess) the car goes almost perfect. any suggestions to fix that?
