216 GTi DOHC - Error Code 9
Posted: Mon Oct 08, 2012 8:16 pm
by pete2783
The twin cam has been playing up recently with an occasional misfire and throwing error code 9 which seems to be related to the cylinder position sensor. It started off being an occasional thing but it has quickly turned into a frequent issue and is now happening all the time.
I've read on a few Honda forums that the cylinder position sensor doesn't often cause a problem and it is more likely timing or even the distributor that can be the cause of the issue.
I'm going to check the resistance across the CYL position sensor and then look at the timing but I thought I'd post up on here to see if anyone has had a similar experience with an error code 9.
Thanks!
Re: 216 GTi DOHC - Error Code 9
Posted: Tue Oct 09, 2012 6:19 am
getting the timing right on the DHOC and getting the tension right is a bit of a mission.
Must have done it 6-7 times before it was right.
Posted: Tue Oct 09, 2012 7:33 am
by carl747
Did you want me to come over pete ?
Posted: Tue Oct 09, 2012 10:45 am
by pete2783
1234dist wrote:getting the timing right on the DHOC and getting the tension right is a bit of a mission.
Ha ha, its 'one of those' jobs, is it?!
carl747 wrote:Did you want me to come over pete ?
Thanks for the offer Carl. To be honest, I'm struggling to find time around work at the minute and the evenings are starting to get dark! The Impreza also needs a power steering pump before I can sell it so I don't think I'll be able to look at the Rover for another couple of weeks or so.
Posted: Tue Oct 09, 2012 4:35 pm
And i bought the correct cam locking tool!!!!
:cursing
Posted: Mon Nov 05, 2012 4:10 pm
by pete2783
Just to update, I think this was nothing more than a poor connection. After a bit of fiddling, it has been running fine for the last week or so. Win!
Posted: Mon Nov 05, 2012 5:47 pm
by carl747
pete2783 wrote:Just to update, I think this was nothing more than a poor connection. After a bit of fiddling, it has been running fine for the last week or so. Win!
:groupwave
Now sell me my bumpers back :angel :wink3 :D :laughing2
Posted: Tue Nov 06, 2012 10:19 am
by pete2783
carl747 wrote:Now sell me my bumpers back :angel :wink3 :D :laughing2
If only I could get my mits on a GTi front lip....!
