Page 1 of 3
Rover 214si, tune ups???
Posted: Sun Sep 02, 2007 12:36 am
by stringy
Right as some know i have a rover 214si (wedge shape) and i'm wanting more power, what tune ups can i get to increase power?? Just want gains on accelerating (maybe top end aswell) cheap ones, we're not talking engine swap or turbos!
Posted: Sun Sep 02, 2007 7:48 am
by Clawjaw
I have a 220 GTi with an K&N induction kit, full Magnex stainless steel exaust with a Magnex cat by-pass that i recently bought and will add on Monday after i get an MOT pass :wink: New plugs i hear can help with performance but to be honest its performance a computer would have trouble finding as its that low :?
Posted: Sun Sep 02, 2007 9:20 am
by whiskeyonesix
Agree with the induction kit and exhaust setup. What about these "drivability" chips you can get? Althought ive heard a few horror stories about them.
A few years ago, I built an old LandRover for rallying - not having much money, I reasoned that the less weight the vehicle was carrying, the faster it would go, so most of the interior went, the steel wheels were changed for alloys (lighter), all of the soundproofing went, and I cut several non-important pieces out of the chassis.
I`m not suggesting you go to these extreme measures, but it worked for me :)
Posted: Sun Sep 02, 2007 6:13 pm
by E_T_V
Which version of the 214 have you got? Is it 8v or 16v is it Carb, single point injection or multi point injection?
In general if you have a 16v MPi, then there isn't a lot you can do easily and cheaply. You can add a free flowing air filter and perhaps a performance exhaust but you won't get much more power out of it.
Ditching weight is a good plan for a track car etc but not very practical for day to day use. Also insurance companies won't like it.
Posted: Mon Sep 03, 2007 6:39 am
by Clawjaw
Nitrous :*laughs*:
Posted: Mon Sep 03, 2007 8:55 am
by stringy
E_T_V wrote:Which version of the 214 have you got? Is it 8v or 16v is it Carb, single point injection or multi point injection?
It's the 214si 16v, injection (dunno if it's mpi or spi??)
ROFL @ the nos idea!
Posted: Mon Sep 03, 2007 12:01 pm
by Cemo
Its more than likely an MPi, is there four plastic pipes coming from the back of the engine block?
Posted: Mon Sep 03, 2007 8:51 pm
by The R8 Man
I'd suggest doing what I'm going to do when my SPi K finally dies....
Fit a standard 1600k, it should go straight in and give you a useful amount of extra hp and torque. My 214 is still having work carried out on it at the moment, cam belt and a new HG, but as long as the bottom end is in good nick and the engine does not burn oil at an alarming rate its staying put.
1600K's are about the same price as 1400 ones and if given a Land Rover head gasket should last for years. A good S/H engine should set you back what, about £350, tuning parts will quickly mount up so in the long run fitting a larger engine sould be the better bet, as a tuned 1400 might not be as strong as a standard 1600k putting out the same amount of power.
Posted: Mon Sep 03, 2007 11:44 pm
by stringy
yea i might look into that, but i'm thinking if i'm gonna put a new lump in it, i might aswell go a get a 620 turbo lump!!!!
Posted: Fri Sep 07, 2007 4:01 pm
by The R8 Man
I've often thought of doing that, but the amount of parts needed would mean finding a 420/220 and stripping that, I think the subframes are different for a start...
The 1.6 should go straight into a 1.4, even the gearbox is identical so just a new clutch, 1.6 ecu and away we go.
