My XUD 7 TD won't stop running after I turn the ignition off. I can even take the key out and wander of, it just keeps ticking over.
My guess (and it's only that, I could be wrong) is that the vacuum pump is at fault, not stopping the fuel flow.
I've never had to deal with something like this without a Hayne's Manual at my side, so I've got some questions.
Where is the vac pump located on a Diesel 200?, what sort of fault should I be looking for, if it is the pump that is faulty?
Also, any other suggestions as to where the problem may lie?
I don't think it is the ignition, since it feels smoothe, and checks out electrically.
Diesel won't die. Vacuum pump?
218 SLD Turbo
British Racing Green/Tempest Grey
E_T_V - Thanks - never ocured to me, I'll check it out in the morning.
Skorpionokx - It did do my head in - when the motor wouldn't stop I opened the bleed screw on the fuel filter to kill it. It wasn't until 30 minutes later that I thought 'Why didn't I just stall it?'.
218 SLD Turbo
maccymaccy
Me too me too...
Hi all;
I have happily stumbled onto this members forum and am so impressed, that I felt inclined to join up. So here I am. Hello everyone
I currently have this same problem on my 218 SLD 'intercooled' turbo. I have called the motor-factors who have quoted me £13 for a new stop=solenoid. I want to fit the unit myself, but am not sure where the stop=solenoid is positioned under the bonnet. Also, will I require any additional washers and/or gaskets during the repair?
Thanks in advance
Andy
ps it's a '95 model as well if that's relevant?
Thanks in advance
Andy
....218 SLD Intercooled turbo Work-Horse! ;-)
Fingermouse
maccymaccy
Thanks E_T_V
Will I need to disconnect the battery as well, or can the work be done as is?
And will there be any complication whilst removing the plastic cover from the engine? It has several rubber pipes leading from/to it and with it been the intercooled model, I dunno if this makes the task more complicated??!
Thanks once again
Andy
Thanks once again
Andy
maccymaccy
Vvvroom vroom :-D
Well, it's working now. New stop-solenoid did the job nicely
The old one had a degraded rubber tip, which was therefore not stopping the diesel from getting to the engine, thus carrying on running after ignition was turned off.
I got given a Bosche solenoid originally from the motor-factors, which I soon realised was the wrong one! I needed a Lucas solenoid, which has a narrower thread (approx. 8mm) and longer body to that of the Bosche (approx 18mm diameter thread!)
I hope this helps anyone that is looking at this with a similar problem?
Thanx for the help peops
Andy
Andy
