Head swaps...
The R8 Man
Head swaps...
I've been offered a bare VVC cylinder head which I believe has larger valves than a standard 1.4/1.6K. Firstly has anyone run a 1.4/1.6K with one of these heads and secondly what is the best cam to use with it? I'm looking at building a warmed up 1600cc K for my GSi and if the VVC head is a straight swap I will go down this route, as it would be far cheaper than having my existing head modified!
The R8 Man
The VVC engine uses larger valves so effectivly it is basically a large valve head, and I think the VVC controls can simply be swapped over for a conventional camshaft/injection system. Head space is apparently limited within the K head and it would be interesting to see if the VVC head would give a 1600 unit a bit more oomph compared to the cost involved in having a standard 1600 K head modified.
I can't comment from personal experience, but yes the VVC head has bigger valves and a lot of people seeking more power do away with the VVC mechs on the 1.8's.
Piper do a conversion kit to take solid cams which can be seen here
http://members.aol.com/_ht_a/DVAndrews/ ... tm#vvchead
Your looking at £95+ for the conversion kit plus cost of cams etc
HTH
Alan
HTH
Alan
