Brake upgrade on 214 16v
Just picked up a 3dr 214 and the brakes are in need of attention, was wondering if there are any easy upgrades such as bigger fronts from a more powerful or more recent car (Rover 25/45 & MG derivatives, 220 etc.) to give it some decent stopping power. As the rears are drums, I'm guessing these are limited to what linings are used but any advice would be welcome.
whiskeyonesix
I`m assuming you`d need to change the calipers aswell? If I was to try and source a set from the scrappy or whoever, what model should I be looking for?
Or could I just get the complete setup "off the shelf"?
Sorry for hijacking the thread btw
'92 Range-Rover V8 (SOLD! Awaiting collection .)
'94 Disco 300Tdi (steam-powered, judging by the performance!)
Sorry, but I am also going to hi-jack this thread.
I am thinking of uprating the brakes on my 218 diesel (as I may need new calipers before long anyway).
I have not really tried messing with brakes to muchy in the past would I be able to do a straight swap for maybe the MG calipers/brakes? Or would it require suspension work, wheel spacers etc?
Currently it has standard suspension and SEi alloys.
Mo
Mo
Hi guys, regarding 214 brake upgrade you are in luck. I have just carried it out on my 214 sei 2 door hatch. The original brakes were 232 mil solid discs. I wanted to upgrade to the 262 mil vented which are fitted om 1.8 diesels, 2.0 litres and turbo,s etc.
Firstl i got some calipers and hangers from the breakers for £35, I thn bought 262 vented discs, these were also drilled and grooved. They cost £45 on ebay with mintex pads. I thought that would do the job, but when i tried one on the car it wouldnt fit. I also had to change the suspension swivel joint that carries the hub. £30 from the breakers. Changed the bearings while I was at it. Lastly changed the break hoses to stainless steel goodridge lines. Massive difference in breaking.
illegalbeast
I had a nose through Rimmer brothers catalogue, and my diesel has the 262mm vented disks and pads. The only improvement I can find are disks and pads of the ZR 160 xpower. Are these actually a marked improvement over the ones I have?
If not I will just stick with the ones I own
Also rimmer brothers list the 238mm in their catalogue, stating models "up to BD234417/908975".
