Rover 200 & 400 Owners Club • Thermostat
Page 1 of 2
Thermostat
Posted: Tue Apr 02, 2019 9:42 pm
by davethepaint
Hi everyone I have read somewhere on here that there is a stat modification for K engined cars can anyone point me in the right diretion please? TIA.
Re: Thermostat
Posted: Tue Apr 02, 2019 10:29 pm
by Mr Teddy Bear
There is a PRV setup really designed for the Freelander that resites the stat and also opens under pressure.
Beef on here manufactures a aluminium alloy housing to replace the plastic OEM job that also involves a resite too.
Send me a message if you want his telephone number, I decided against publishing it on the web.
Re: Thermostat
Posted: Wed Apr 03, 2019 8:41 am
by davethepaint
Thanks will do if I buy the car 👍👍
Re: Thermostat
Posted: Mon Sep 27, 2021 11:28 am
by GTiJohn
This is the top hose assy that was brought to the BL Rally at MK yesterday by the very nice fella in the BRMs - didn't catch his name, sorry... :slapme
I thought I'd have a go at fitting one when I change the HG on the vi soon.
Does anybody have any spares of these from a Freelander by any chance ?
Or any of the hoses that could be modified to fit?
I have one of these already
but it's further complicated that I'm going to fitting A/C at the same time so will have to change the rad to have an angled-upwards top hose connection so my spare will only provide some sections
Re: Thermostat
Posted: Mon Sep 27, 2021 11:57 am
your friendly RR has a couple of these on the shelf :cool
Re: Thermostat
Posted: Mon Sep 27, 2021 12:38 pm
by JOHNDQ
You can get the PRT kit of next to nothing from Britpart you just then need a 28/32mm 90 degree silicone hose to join the PRT to the bottom radiator. I would also advise using the later grey PRT thermostat housing as that's especially designed for the k-series (soft relief spring and opens earlier)
Re: Thermostat
Posted: Mon Sep 27, 2021 3:02 pm
by GTiJohn
RoverRevival wrote: Mon Sep 27, 2021 11:57 am your friendly RR has a couple of these on the shelf :cool
Please send pics and prices! :clapping
Re: Thermostat
Posted: Mon Sep 27, 2021 4:43 pm
by GTiJohn
JOHNDQ wrote: Mon Sep 27, 2021 12:38 pm You can get the PRT kit of next to nothing from Britpart
Not finding the Britpart site particularly easy to use... :mad
But found lots of the kits on ebay under the part number PCH001190. Most photos suggest they have cream colour housing though...
Re: Thermostat
Posted: Tue Sep 28, 2021 3:43 pm
by JOHNDQ
GTiJohn wrote: Mon Sep 27, 2021 4:43 pm
Yes unfortunately you have to buy the grey stat separate and it's quite expensive
Re: Thermostat
Posted: Tue Sep 28, 2021 10:13 pm
by 961tat
Been running mine for 4 years I used stainless tee piece from a 75 turbo and hoses adapted to suit and can still fit in 160 vvc airbox works well .
https://ibb.co/0p0h0kX
https://ibb.co/Jv2GLh0
DMGRS sell them grey and white plus the tee piece but not stainless your just need to rig up the hoses using your existing plus a bit extra :D and a low coolant expansion bottle is always a good up grade 😉
https://ibb.co/7gfwK6G
https://ibb.co/sVdy1Pp
https://ibb.co/4V99B8N
