Page 1 of 3
R8 overhaul cost
Posted: Sun Aug 07, 2022 5:12 pm
by henryiett
Hi, I am just looking at costing the restoration of my R8 214Si that hasn't run since about 2002. It is in good cosmetic condition. Just needs a total mechanical restoration. I am just looking at rough ballpark figure to get it sent off for overhaul at a specialist
Re: R8 overhaul cost
Posted: Sun Aug 07, 2022 5:38 pm
by Paul_1978_yorks
If you’re wanting all gaskets doing, full service, including brake fluid, radiator, plus brake discs and pads etc etc, I reckon you’re looking at £1k
Posted: Sun Aug 07, 2022 5:53 pm
by henryiett
Paul_1978_yorks wrote: ↑Sun Aug 07, 2022 5:38 pm
Like idk if that is enough after that engine hasn't started since 2002, as I suspect it needs a full rebuild
Posted: Sun Aug 07, 2022 7:46 pm
you'll need tank drop, lines cleaned, fresh fuel.
all fluids replaced, belts, water pump, thermostat maybe head gasket depending on the mileage as if you are doing the belt there isn't that much more labour involved.
head of you can check the bores and piston rings for rust.
If the car was stored with coolant in, great. If not and new rad may be needed.
20 years you'll also need tyres
Then obviously bushes ect checked and you are ready for mot.
Give us a shout if you need any help
Posted: Sun Aug 07, 2022 7:47 pm
by henryiett
It was parked one day and never started again all fluids inside. I would get it all done
Posted: Sun Aug 07, 2022 7:48 pm
by henryiett
RoverRevival wrote: ↑Sun Aug 07, 2022 7:46 pm
How much would that roughly cost? Like if u were doing it how much would u charge?
Posted: Sun Aug 07, 2022 7:49 pm
for everything you are easy 1500-2000.
Tyres alone is £250-500
Posted: Sun Aug 07, 2022 7:52 pm
by henryiett
RoverRevival wrote: ↑Sun Aug 07, 2022 7:49 pm
Is that including labour?
Posted: Sun Aug 07, 2022 7:54 pm
yes, and depending on your location we can collect on our recovery truck.
Posted: Sun Aug 07, 2022 7:58 pm
by henryiett
RoverRevival wrote: ↑Sun Aug 07, 2022 7:54 pm
Wow, that's cheaper than I expected
