R8 overhaul cost
henryiett
R8 overhaul cost
Post by henryiett »
Hi, I am just looking at costing the restoration of my R8 214Si that hasn't run since about 2002. It is in good cosmetic condition. Just needs a total mechanical restoration. I am just looking at rough ballpark figure to get it sent off for overhaul at a specialist
Rover 214si 1990
Re: R8 overhaul cost
Post by Paul_1978_yorks »
If you’re wanting all gaskets doing, full service, including brake fluid, radiator, plus brake discs and pads etc etc, I reckon you’re looking at £1k
henryiett
Post by henryiett »
Paul_1978_yorks wrote: Sun Aug 07, 2022 5:38 pm If you’re wanting all gaskets doing, full service, including brake fluid, radiator, plus brake discs and pads etc etc, I reckon you’re looking at £1k
Like idk if that is enough after that engine hasn't started since 2002, as I suspect it needs a full rebuild
Rover 214si 1990
you'll need tank drop, lines cleaned, fresh fuel.
all fluids replaced, belts, water pump, thermostat maybe head gasket depending on the mileage as if you are doing the belt there isn't that much more labour involved.
head of you can check the bores and piston rings for rust.
If the car was stored with coolant in, great. If not and new rad may be needed.
20 years you'll also need tyres
Then obviously bushes ect checked and you are ready for mot.
Give us a shout if you need any help
henryiett
Post by henryiett »
It was parked one day and never started again all fluids inside. I would get it all done
Rover 214si 1990
henryiett
Post by henryiett »
RoverRevival wrote: Sun Aug 07, 2022 7:46 pm you'll need tank drop, lines cleaned, fresh fuel.
How much would that roughly cost? Like if u were doing it how much would u charge?
Rover 214si 1990
for everything you are easy 1500-2000.
Tyres alone is £250-500
henryiett
Post by henryiett »
RoverRevival wrote: Sun Aug 07, 2022 7:49 pm for everything you are easy 1500-2000.
Is that including labour?
Rover 214si 1990
yes, and depending on your location we can collect on our recovery truck.
henryiett
Post by henryiett »
RoverRevival wrote: Sun Aug 07, 2022 7:54 pm yes, and depending on your location we can collect on our recovery truck.
Wow, that's cheaper than I expected
Rover 214si 1990
