1994 216i Cabrio with Honda DA16A8 Engine
awcope
Post by awcope »
Hi,
Other than the ECU blinking to read codes is there a plug on these cars where codes can be read from, and if so where is the plug and what does it look like?
Thanks!
Tony Cope
Sydney Australia
tonywcope@gmail.com
1994 Rover 216i Cabrio in Sydney
2004 Rover 45 1.8 Hatch in London
Re: 1994 216i Cabrio with Honda DA16A8 Engine
Nope, that's it I'm afraid...
The Workshop manual, might give you other component tests you can perform to root-cause a problem.
(Many manuals are available as a downloads in the members area :cool )
awcope
Post by awcope »
Thanks John - I have read what appear to be the relevant manuals on the club website and while I can see the auto lockup is triggered by the ECU I cannot find anything that gives the logic flow of what inputs result in the auto lockup being disabled.
Any clues anyone??
Tony Cope
Sydney Australia
tonywcope@gmail.com
awcope
Post by awcope »
Found this capped off green three pin plug near the windscreen wash tank. What is it for?
Thanks Tony
Tony Cope
Sydney Australia
tonywcope@gmail.com
awcope
Post by awcope »
Oops - with photo this time!
Mystery 3 Pin Plug
Mystery 3 Pin Plug
Tony Cope
Sydney Australia
tonywcope@gmail.com
awcope
Post by awcope »
Bump - does anybody know what this green three pin plug is for?
Tony Cope
Sydney Australia
tonywcope@gmail.com
Roverlike
Post by Roverlike »
If you have Lucas 5AS alarm system that 3-pin green plug should be diagnostic connector for Lucas 5AS alarm system.
awcope
Post by awcope »
Thanks Roverlike!
Tony Cope
Sydney Australia
tonywcope@gmail.com
