My headlights recently started playing up.
Side lights work and so does high beam but no head lights. Any help appreciated.
Head lights
Re: Head lights
Have you verified lack of voltage?
Re: Head lights
I had this once and it was a relay under the dash (driver's side). Main beam worked as did sidelights but not dipped beam.
GONE until the next time
Re: Head lights
Sounds silly but have you checked the bulbs ?
It is possible you may have had a surge & blown both Dip-beam filaments.
Re: Head lights
Thanks for the help.
It did turn out to be the pink relay under the dash.
All the available help and advice from members is a great reason to be a member of this club.
MattJonesOne
Re: Head lights
Sorry to revive an old thread. But where under the dash was the relay?
Re: Head lights
When you're lying upside-down in the driver's footwell, looking up at the underside of the dashboard, it's under the dash, top left hand corner (as you look at it). Pink, as stated above. You can't miss it but it is a bit fiddly to get at.
1989 216GSI + 1990 216GSI + 1997 416 Tourer + 1993 220 GTi Turbo + Triumph T160V
MattJonesOne
Re: Head lights
I might be being dense, but I can't see a pink relay. I've attached pics from under the dash if anyone could point me in the right direction
- Attachments
Re: Head lights
What year and model is your car please?
