Leaking rear tail lights
Firose
Post by Firose »
Hi,
Just managed to trace the water gathering in the boot to one of the tail lights.
If I was to use clear silicone sealant would that work and do I need to re-use the faom surround seal again or not ?
Thanks in advance
Firose
1995 220 GSi Turbo
John W
Re: Leaking rear tail lights
Post by John W »
Clear silicone is fine. I would use the gasket too and silicone both sides.
Kind Regards
John
1994 216 SE Cabriolet
1993 Rover 827 Coupe
1999 Rover 820 Sterling auto
1964 2000 (P6)
1982 Porsche 924
1980 Ford Fiesta MK 1
1983 Ford Capri 1.6LS
Post by E_T_V »
Exactly what I've done with mine.
Silicone the foam seal onto the light unit (you'll see the mark pressed into the foam.
Then silicone the back of the foam in the same place so that you effectively seal the unit to the car when you replace it and nip the nuts up.
pulsar214
Post by pulsar214 »
I had the same on my 214. I cured by simply adding another foam gasket and it was cured 100&
If at first you dont succeed hit it with a hammer and have a fag!
