Advise to SELL SELL SELL
I have owned my 1996 or 97 Rover 416 Si for 5 years. Very quirkie but when the security system allows me, it runs very nicely. But every mechanic and auto dealer on Ibiza, Spain, says "get rid of it NOW before it blows up" or some variation to those words. What gives? Am I the only one in the dark? I never see any mention in here about engine problems. I admit I never worry about my cars cause they normally run flawlessly....
So long as you look after the cooling system chances are the car will last you for years. Check the coolant level at least once a week and NEVER drive with a low level. Also if the car ever starts to overheat then STOP immediately.
They do have a weakness for headgaskets but then the later headgasketss are better and most failures are caused by people driving with a low coolant level (they have a very very small capacity compared to most cars).
Ours was on 120k miles before it went, and it got abused almost everyday
You don't state if you have the Rover K-series or the Honda engine. I've just got hold of a 216SLD that has the Honda lump. Was the 216Si a K-series fitting?
I'm staying clear of K-series after my missus's loss. Her 200 Bubble overheated one day. It passed all the tests but she couldn't trust it again.
Make sure your radiator is good. It's a cheap replacement.
'93 Rover 420 SLi in Nightfire with that bonnet hump
'79 Leyland Princess in a sort of white
'96 BMW 523i in that Panama Brown Metallic
'84 Alfa 33 QO track car in-build ran out of money again
sorry, I now think i do need some glasses...Dr Skatiechik wrote:It will be a K series bubble if it is a 1996 model.
