Search found 8 matches
by masrover
Sat Nov 21, 2009 12:11 pm
Topic: Fan problem on a 216 with a Honda engine
Hi all, As the title suggests I've got a problem with my cooling fan. By way of background, I've recently replaced the head gasket. Everything is working fine, timing now set correctly, but the fan doesn't cut in when it gets hot. The fan works, I've hard wired it to test. I've tested the circuit wi...
by masrover
Sat May 02, 2009 11:19 am
Topic: Idling fast and other issues
Re: Idling fast and other issues
Thanks for the replies.
The temp gauge usually sits just below half way...........................but its nearly exploded when I blew the head gasket!
by masrover
Wed Apr 22, 2009 11:06 am
Thanks, I've got the error code booklet already. I've cleared that TC error.
I'm still having problems with the fast idling though and the fan
by masrover
Tue Apr 21, 2009 7:09 pm
Hello all, I'm slowly buts surely getting my mum's 216 back together after a HGF. Its a 1991 216 GSI with the Honda SOHC engine. Its all back together but there's a error on the ECU which seems to suggest that there's a problem with the Top Dead Centre Sensor. What might be the trouble and how do i ...
by masrover
Wed Mar 18, 2009 10:30 am
Topic: Rover 216 Distributor cap
Hi,
Does anyone know the part number for a distributor cap for a 1991 Rover 216 with a Honda engine?
The one that was supplied to me by Camberley Auto Factors is the wrong one.
Thanks in advance!
by masrover
Mon Jan 19, 2009 1:10 pm
Topic: 216 Head gasket head ache. New gasket doesn't fit
I can really be stupid sometimes! I had it on upside down!! :D
by masrover
Mon Jan 19, 2009 12:40 pm
Hi Jet,
I had thought that. I did ask specifically ask for the Honda engine one!
Are they're any other tell tale differences between the two?
by masrover
Mon Jan 19, 2009 12:28 pm
Hi, Newbie. My mum's 216 GSI has blown its head gasket. I have tried to fit a new one, but it doesn't fit! On the back row, the holes for the dowels don't line up with holes on the block or the head - the result is that the dowels won't go through. Have I bought the wrong one? I thought maybe I'd be...
