Search found 770 matches
by 214cab
Fri May 26, 2017 7:00 am
Topic: Cabby Rear Screen replacement
Re: Cabby Rear Screen replacement
They do unzip but you need to remove the side flaps & there is a metal bar that holds the base of the screeen down, often these bars are very rusty!
by 214cab
Fri May 26, 2017 6:57 am
Topic: rover cabriolet roof
Re: rover cabriolet roof
I've got a serviceable 'ear' for the drivers side.
It's been repaired with some bracing & riveting but does the job.
Also have a rear panel that's a little crusty but appears serviceable with a run over with a wire brush attachment.
Where are you based?
by 214cab
Mon Feb 22, 2016 7:50 am
Topic: 216 cabbie front window adjustment
Re: 216 cabbie front window adjustment
Haha yes I'm sure you'll cope!
Manual does elaborate any further.
I stumbled across that set on eBay for sale locally think I paid £10 as the only bidder.
by 214cab
Sun Feb 21, 2016 9:17 pm
Topic: Electric wing mirror glass fixing - should it be easy to snap into place?
Re: Electric wing mirror glass fixing - should it be easy to snap into place?
This was pre me and yes i assumes someone whacked the mirror, i replaced the glass that was cracked but couldn't ever get it to fit right!
I kept meaning to buy a full replacement mirror (beware you need a cabriolet mirror though, Coupe one won't fit!)
by 214cab
Sun Feb 21, 2016 9:15 pm
Let me know if you need me to dig out the page for the 'Front Door Pad'
by 214cab
Sun Feb 21, 2016 9:04 pm
I'm pretty sure the answer will be somewhere in one of these....
Just looking for you!
by 214cab
Wed Feb 17, 2016 8:30 pm
Topic: Ashleys Rover - progress
Re: Ashleys Rover - progress
I'm missing her! ;-( but glad she has found a good home with Martin.
I may have a spare fog switch in the garage - if i stumble across it i'll let you know.
by 214cab
Mon Aug 10, 2015 6:51 pm
Topic: Newbie from Bournemouth
Re: Newbie from Bournemouth
Ahh much better with a quick clean!
by 214cab
Tue Aug 04, 2015 8:03 pm
Topic: Rover Cabriolet swap over Hood help queation
Re: Rover Cabriolet swap over Hood help queation
Roxy I can't tell you how easy the hood is to swap over, it's almost literally two circlips, a couple of screws & 6 bolts.
Little more work if you are also swapping the rear window section.
You only really need a spare pair of hands to lift roof off / on.
by 214cab
Sun May 17, 2015 9:02 pm
Topic: black cabriolet
Re: black cabriolet
Early ones were solid black later ones were metallic charcoal black
