Search found 92 matches
by Colonel Mustard
Tue Jan 06, 2026 8:34 pm
Topic: reset central locking Rover 25
Re: reset central locking Rover 25
It might be worth checking the fuse for the alarm/immobiliser, which if memory serves me correctly is fuse 8 in the engine compartment fuse box:
by Colonel Mustard
Mon Sep 29, 2025 9:13 pm
Topic: Members can access all the Technical article in the Viking
Re: Members can access all the Technical article in the Viking
For both The Viking downloads and the separate Rover documents download area, there is a two hour embargo on downloading the same file again to avoid the website bandwidth being exceeded. You should be able to download a file again after this period. If you continue to have problems you would be bes...
by Colonel Mustard
Mon Sep 15, 2025 3:02 pm
Topic: Key fob programming for a Rover 45
Re: Key fob programming for a Rover 45
If it is the Lucas 5AS type have a look at: https://store.rover-coupe.com/services/ ... plied_fobs. The discount code for members can be found at: https://rover200.org.uk/forums/topic?p=105684#p105684
by Colonel Mustard
Wed Jul 09, 2025 5:22 am
Forum: Events and Meetings
Topic: Roverfest 2nd & 3rd August, Weston Underwood. MK46 5JS
Re: Roverfest 2nd & 3rd August, Weston Underwood. MK46 5JS
1. Montegoman
2. 220 GSi turbo
3. Mrs 220 GSi turbo
4. Colonel Mustard
by Colonel Mustard
Sun Jun 29, 2025 10:57 am
Topic: VIN Decoder Question
Re: VIN Decoder Question
The issue will probably be the trim level (6th character of VIN), as the source of VIN data used is a bit vague for this (plus Rover had the habit of using the same character for different model descriptions over the years - eg M was used for both 'S' and 'SE' R8 models). Unfortunately the trim leve...
by Colonel Mustard
Mon Jun 23, 2025 10:03 am
Topic: Vin number
Re: Vin number
R8 216 Coupe with Honda D16Z2 (SOHC) engine and 4 speed automatic gearbox.
by Colonel Mustard
Sat May 31, 2025 3:35 pm
Topic: Series 2 (97-98 MY) Coupe Wiring Diagram
Re: Series 2 (97-98 MY) Coupe Wiring Diagram
I've only got the 96MY diagrams on my RAVE CD, so that may not be of any use to you. But I've uploaded it to the Members Area Rover Documents Download page just in case it might help.
by Colonel Mustard
Mon Mar 10, 2025 6:57 am
Topic: Small Hole Front Subframe Drivers Side - Car Ender?
Re: Small Hole Front Subframe Drivers Side - Car Ender?
See
MEMBERS AREA -> Members Discounts -> Repair Panels -> HH-R front jacking points
for details on how to get the club member discount for these items.
by Colonel Mustard
Fri Jan 24, 2025 12:52 pm
Forum: The Gallery
Topic: Brochure shots
Re: Brochure shots
I always think this photo from the past events page (Lucknam Park in 2019) looks like a brochure shot:
by Colonel Mustard
Mon Sep 30, 2024 8:45 pm
Topic: BL Autumn Rally 29th September 2024
Re: BL Autumn Rally 29th September 2024
Jeremy's photos from Sunday can be found under Events -> Past Events.
