Search found 3 matches
- Tue Jul 03, 2012 2:26 pm
- Topic: 220 Coupe Rear Bumper Removal
The rear bumper on my 220 coupe is sagging on the drivers side I've had a look from underneath and I think the metal bar has rusted. I want to remove the rear bumper to have a good look. I have found 2 bolts in the boot which appear to be from the metal bar, does anyone know if there are any more at...
- Fri Feb 24, 2012 6:36 pm
- Topic: 220 Coupe Turbo 94 - hesitant on throttle, revs drop, stalls
Re: 220 Coupe Turbo 94 - hesitant on throttle, revs drop, st
Thank you for the help Paul and E_T_V, its much appreciated. Have blanked off the third nipple, this resulted in the car running worse and the hesitation on the throttle being more pronounced with the car more or less stalling every time i let the revs drop. have taken throttle body off and given a ...
- Sun Feb 19, 2012 4:36 pm
Hello everyone Rover 220 coupe turbo 94 T series when accelerating revs drop and then recover. if revved high >2000 rpm and then allowed to fall revs drop and car nearly stalls, sometimes does stall. car runs OK at idle have tried the stepper motor reset advised on this forum (ignition to 2, 5 press...
