Search found 3 matches
by bobw
Sat Apr 28, 2012 7:06 am
Topic: Mystery Coolant Leak
Re: Mystery Coolant Leak
I had a similar problem with mine just after I bought it. Traced it to the inlet manifold gasket. Difficult to spot if it's only a small leak. Mine was at the left hand (timing belt) end of the manifold and I had to look hard to see it. I replaced the gasket (which had been done before as it was a g...
by bobw
Wed Apr 25, 2012 6:48 am
Topic: Cabriolet Rear Window Demister
Re: Cabriolet Rear Window Demister
Many thanks for posting the details. The relay position is in the main fuse box, top right (ish) as you look at it. The wiring diagram and the fault finding guide both refer to a relay so I think it should have one. The reason I wanted to be certain is that they're around £30 from Rimmers so this ma...
by bobw
Mon Apr 23, 2012 12:00 pm
The rear demister fan on my recently acquired cabriolet doesn't work. The indicator light in the switch doesn't work either, which prompted me to check the fuse. When I checked in the fuse box I found that the relay for the heated rear window is missing. Now this may seem a stupid question, but with...
