Search found 33 matches
by awcope
Sun Mar 15, 2026 11:00 am
Topic: Cabriolet boot inaccessible
Re: Cabriolet boot inaccessible
And drink the beer on the way!! :D :D :laughing2
by awcope
Sun Feb 08, 2026 4:00 am
Topic: 1994 216i Cabrio with Honda DA16A8 Engine
Re: 1994 216i Cabrio with Honda DA16A8 Engine
Thanks Roverlike!
by awcope
Fri Feb 06, 2026 3:23 am
Topic: Haynes Manual 3344 - Engine Management & Fuel Injection Systems
Re: Haynes Manual 3344 - Engine Management & Fuel Injection Systems
Bit the bullet and ordered a No 3344 Haynes Manual from the UK - arrived in Sydney within a week - very interesting section on the Rover Honda PGM -FI. It explains in some detail how the various sensor and actuators work, but no real detail of what the ECU does with information from particular senso...
by awcope
Fri Feb 06, 2026 3:18 am
Topic: 1994 216i Cabrio with Honda DA16A8 Engine - Auto Lock Up
Re: 1994 216i Cabrio with Honda DA16A8 Engine - Auto Lock Up
I have hopefully got this issue fixed - it appears the lambda oxygen sensor was faulty - now replaced and so far so good with the autobox torque converter locking up again. But why would a faultly lambda sensor stop the auto lockup?? Wish I could find documentation as to all the algorithms in the ECU!
by awcope
Fri Feb 06, 2026 3:13 am
Bump - does anybody know what this green three pin plug is for?
by awcope
Wed Jan 07, 2026 11:50 am
Oops - with photo this time!
by awcope
Wed Jan 07, 2026 11:47 am
Found this capped off green three pin plug near the windscreen wash tank. What is it for?
Thanks Tony
by awcope
Fri Jan 02, 2026 11:01 pm
Topic: Rear Seat Buckle Casing in Beige Wanted
Re: Rear Seat Buckle Casing in Beige Wanted
All good - now have bought two in beige. Thanks Tont
by awcope
Fri Jan 02, 2026 9:32 am
Yes - already studied the wiring diagram - the auto lockup is directly controlled by the ECU - so the mystery is what logic is built into the ECU that drops out the auto lockup?
by awcope
Fri Jan 02, 2026 9:26 am
Thanks - have PM'd you!
