Search found 77 matches
by davieboy
Wed Dec 17, 2008 9:51 pm
Topic: up grades on the way!!!!
Ah good point, thats why I didnt go down that road *laughs*. Just not practical for the roads of south wales. you could try a set of coil overs with adjustable hieght, that way you can play around until you get the ride and hieght that you are happy with. Not cheap though, saw a full set available f...
by davieboy
Wed Dec 17, 2008 3:02 pm
yes I was wondering that, whats the problem ? its easy enough on the 200 series. I did my sons in about 3 hours start to finish. new springs and shocks using the top mounts from the original shocks.
by davieboy
Tue Dec 16, 2008 9:07 pm
Good luck fitting it all. I did all my sons on his 214 sei. She is mint and a bit different. I fitted heaters in the front seats and went for the EL dials and heater controls, they are white in the day and green or blue with red numbers when lit and have adjustable brightness. Much better than stand...
by davieboy
Sat Oct 25, 2008 2:58 pm
Topic: Boot leakage
sunroof drains will run down the rear pillar and out through the boot floor via a rubber grommet. if you have a 5 door it could be the little quarter glass leaking or on a 3 door like mine the large quarter window maybe ?
by davieboy
Fri Oct 24, 2008 7:25 pm
Topic: Rear wiper...
Try replacing the relay next to the drivers side tail light if you have a spare, check the earth is good as some times it gets corroded.
by davieboy
Fri Oct 24, 2008 6:57 pm
Topic: Boot leakage
Most likely a rear light seal, can also check the boot seal for any breaks. Easiest way to check is remove the rear shelf, boot carpet trim around rear lihgts and the two side covers that go over the wheel arches. this will leave the boot bare. then drop the backe seats and have some one sit inside ...
by davieboy
Thu Oct 02, 2008 9:29 pm
Topic: 200 and Coupe Top Spoiler Differences Explained
nice one that should clear things up, well maybe you never know with some people :*laughing my fat rear end off*
by davieboy
Tue Sep 30, 2008 9:22 pm
Topic: Alternators
BULLS--T is all I could reply to that statement. If these have actually failed there must be something on your car causing them to fail premarturely ( sorry about da spelling :laughing2 ) My sons 1994 has its original and thats fine, 4 units for that milage is far from normal, 2 maybe more like it. ...
by davieboy
Sat Sep 20, 2008 1:24 pm
Topic: Manifold change.
Ah that sounds like a plan. I did ask for advice previously regarding this exchange but didnt get any help. That sounds as if it could be the problem, i wasnt aware of yhis procedure. When I say it was running bad it would start but not tick over, you had to keep you foot on the accelarater pedal to...
by davieboy
Fri Sep 19, 2008 8:32 pm
Manifold change.
Has anyone on the site fitted an alloy manifold in place of their later shite looking plastic one. I had the alloy type on my old 214 sei M reg. I now have another 214sei which also an M reg but has the ugly plastic job. I fitted it last week but the car was running terrible. What I need to know is ...
