Search found 70 matches
by Pencil Tip
Wed Oct 09, 2019 9:23 am
Topic: T-series engine management fuse keeps blowing
Re: T-series engine management fuse keeps blowing
Please does anyone have any electrical knowledge to help diagnose this fault? I have a Rover electrical fault finding workshop manual, but it is for the 1.4 & 1.6 engined models. Has anyone a copy to cover the 2.0 t-series?
by Pencil Tip
Sat Oct 05, 2019 7:09 pm
Good thinking Craig. Thanks. :)
by Pencil Tip
Sat Oct 05, 2019 7:01 pm
Yes, a sinking feeling on reading that Craig. I was thinking maybe a short to earth on the lambda senor or ignition coil? Incidentally, I swapped two of the yellow main relays in the engine bay fuse box, in case of a bad relay, but same fuse blowing issue. It's got me. How can it be okay one moment ...
by Pencil Tip
Sat Oct 05, 2019 4:43 pm
I have not driven the 220 for about 3 weeks. Negative lead was disconnected from the battery to preserve battery capacity. Checked voltage before starting and it was only 12.21 volts. I thought, there is no way she is going to start without the booster pack. To my surprise, she started and idled nic...
by Pencil Tip
Wed Aug 14, 2019 5:47 am
Topic: T-series engine cooling fan inoperative
Re: T-series engine cooling fan inoperative
Ah, no mine just has one fast speed.
by Pencil Tip
Tue Aug 13, 2019 5:21 pm
Thanks for the info.
Yes, mine has a second smaller fan in front of the a/c condensor. What does the 2 stage fan actually do? Mine has only cycled on and off during prolonged engine idling.
by Pencil Tip
Tue Aug 13, 2019 4:18 pm
Okay. Both fuses are good, as is the relay. I disconnected and shorted out the radiator sensor wiring to fool the ECU into thinking the sensor has gone closed circuit, i.e. an over-temperature engine situation and the fan does work. So, perhaps I can conclude that the radiator sensor is bad. Does th...
by Pencil Tip
Tue Aug 13, 2019 1:33 pm
Thanks for your help guys.
by Pencil Tip
Mon Aug 12, 2019 10:12 pm
I have noticed that my cooling fan is not operating when it should. I was sat idling at temporary traffic lights and noticed that the temperature gauge was above normal. Is the sensor on the engine or is it the little one on the side of the radiator? Could it be a bad relay? If so, where is it locat...
