Search found 15 matches
- Tue May 04, 2021 8:29 am
- Topic: bonnet for tourer
Re: bonnet for tourer
Thanks for all the helpful response. Mine is a 1.8 turbo so no issues with bulges so to speak.
- Mon May 03, 2021 3:36 pm
bonnet for tourer
Hi guys
Might sound like a daft question but does a bonnet from a 200/400 R8 fit the R8 tourer?
Cheers
Cheers
- Sat Oct 31, 2020 8:07 pm
- Topic: Air in diesel filter
Re: Air in diesel filter
Before I ended up spending more money and considering I cleaned out the intercooler etc I thought I would try an Italian service. That did the trick and I have now regained the power I thought I had lost. Thanks for everyone's input.
- Sun Oct 18, 2020 8:44 am
Thanks for that I'll see what I can find on the citroen/peugeot forums then.
- Sun Oct 11, 2020 3:43 pm
After much researching and thinking with a beer at hand I have finally sorted the oil issue. It turns out that despite the previous person who replaced the turbo saying that all air related items had been cleaned when the new turbo was fitted it turns out that the problem was in the intercooler whic...
- Thu Sep 17, 2020 7:32 pm
The L series diesel seems like a good swop and a lot quieter than my XUD7. Thanks for the info. As far as the air leak is concerned have now sorted it and am embarrassed to say it was simply the top seal on the fuel filter had twisted and got pinched. Hey Ho alls well that ends well new seal fitted ...
- Sat Sep 12, 2020 4:48 pm
Thanks for the assit guys plenty of useful stuff. I;ll get checking and see what I can sort. Once again thanks.
- Fri Sep 11, 2020 5:14 pm
Thanks for the comments about the engine swap but in the meantime I still need to use the car so any ideas about the air in the fuel as its frustrating as hell.
- Fri Sep 11, 2020 11:16 am
Hi all I have a problem with my Blue snail. (418 TD Diesel tourer) I have to bleed the air out of it every morning at the filter which is easy enough but an absolute pain. I have changed the filter, return pipes, injectors and glow plugs prior to the air in problem so would appreciate any ideas as t...
- Fri Feb 21, 2020 9:49 am
- Topic: Rover Tahiti Blue
Re: Rover Tahiti Blue
My local Halfords usually stock 2 x Tahiti Blues but the one which seems to match closest is Tahiti Blue 1993 which seems to match previous posts. Depends how weather beaten your existing paint is.
