Search found 15 matches
by dale214
Tue Jun 01, 2021 8:37 am
Topic: Head lights
Re: Head lights
Thanks for the help.
It did turn out to be the pink relay under the dash.
All the available help and advice from members is a great reason to be a member of this club. :D
by dale214
Mon May 17, 2021 8:56 am
Topic: Head lights
Head lights
My headlights recently started playing up.
Side lights work and so does high beam but no head lights. Any help appreciated.
by dale214
Wed Jun 03, 2020 11:27 am
Topic: Engine won't start
Re: Engine won't start
The car failed to start again this morning.
Am I right in thinking that if the immobilizer light goes out on the dash then its all as it should be.?
by dale214
Tue Jun 02, 2020 11:56 pm
I was told to press the lock button on my key fob 5 times with ignition on to release immobilizer. Tried it and it worked. :clapping Anyone heard of this before? After reconnecting the battery i would lock the unlock car with the key. Then i would turn the ignition on and press the unlock button onc...
by dale214
Tue Jun 02, 2020 10:34 am
Thanks for all advice given. I changed the rotor arm spark plugs and crank censor. But still would not start. It has fuel and spark and timing is correct. Immobilizer light goes out aswell. After several days tinkering it suddenly started. I ran the car for to two weeks with no problems. Then it sta...
by dale214
Mon Apr 20, 2020 7:32 pm
The pump does prime and fuel comes out of feed when tested. I wondered if the pump could be weak and not pumping at required pressure.
I was thinking about the crank censor next.
But what's annoying is that I have fuel and spark!
yet it will not start!.
by dale214
Mon Apr 20, 2020 3:53 pm
Engine won't start
Looking for advice. Recently got my 214 sei back on the road after a few years lay up. Started first time every time and ran beautifully. After a couple of days the engine would cut out after idling comfortably at traffic lights. Then it would be difficult to start. After I left it 5min and a long s...
by dale214
Sun Mar 15, 2020 9:46 pm
Topic: Cutting out engine.
Cutting out engine.
Everytime I wash my car with the engine running
the engine will cut out when water runs down the front screen and down the front scuttle.
Any idea's what its touching to cause an earth?
Thanks.
by dale214
Sun May 19, 2019 11:25 pm
I believe the top end is ok timing wise.
Ive timed the crank using the mark on the front of the pully .
Its on the mark to the right of TDC.
Before i had it on TDC.
This made it run like a bag of bolts.
where should the mark on the back of the pully be facing.?
Thanks for all advice.
Cheers.
by dale214
Sun May 19, 2019 4:44 pm
Engine won't start
I Have a 1.4 k series in a 214. I changed the cambelt a while back and since then the engine will not start. The imobiliser swithes off as it should and it has fuel and spark. Ive cheched the timing and it all seem correct but it still won't start. Tried easy start and it does nothing. Dead as a doo...
