Search found 499 matches
by Plodder
Thu Jul 09, 2026 11:54 am
Topic: Bumper Rubber strip clean up
Re: Bumper Rubber strip clean up
Well the pencil eraser trick worked for me :)
Removed most of the white marks left from not being careful enough with the polish. Needs further treatment to sharpen it up a little bit more but pleased with the result
by Plodder
Thu Jul 02, 2026 3:19 pm
According to an internet search, you can do it using a Pencil Eraser. There's a YouTube video showing it seems to work, some positive comments agreeing on its efficacy but one-or-two saying it didn't work for them. Haven't tried it myself but I will. https://www.youtube.com/watch?v=QUyjrubOCOA That...
by Plodder
Wed Jul 01, 2026 9:49 pm
Thanks for all the recommendations.
Will have a look through all the products suggested and perhaps trial one or two.
I'll even try doing half the trim so I can photo before and after treatment .
Thanks again
by Plodder
Tue Jun 30, 2026 8:28 pm
Anybody got any tips on how to clean or blacken the rubber strips on my bumpers. I think they are discoloured with polish. Tried using Auto Glyn Vinyl and Rubber care spray but it doesn't really get rid of the white marks.
Anyone found a successful solution?
by Plodder
Tue Jun 23, 2026 12:08 pm
Forum: Events and Meetings
Topic: Powderham Car Show 2026
Re: Powderham Car Show 2026 July 11th-12th
I’m attending this show with my local club, Torbay Old Wheels Club (TOWC). Not sure which of the 2 days I will be there but will post that nearer the time. I believe another member with a red 216 coupe will be there. I know it clashes with the event at Gaydon but please say hello if you are attendin...
by Plodder
Mon Jun 22, 2026 10:21 am
Topic: Dart Farm Car Show - 21st June 2026
Re: Dart Farm Car Show - 21st June 2026
Good day at Darts farm yesterday with a good selection of Rovers including 2 x 416’s , 1 x 216 coupe and a 416 HHR.
I was also the jam in a Rover sandwich with a Rover P4 and a Rover Vitessse SD1,
by Plodder
Thu Jun 18, 2026 1:28 pm
Topic: Rimmers Part Drawing Removal
It appears that Rimmers have moved their assembly drawings for the early R8 variant. All they appear to initially show is a list of parts . You now have to click on one of these parts to see the diagram and the list of part numbers. Disappointing and pointless change in my opinion . Perhaps its beca...
by Plodder
Thu Jun 18, 2026 1:03 pm
Topic: Rover 214Si 3 Door Rubbing Strip Removal
Re: Rover 214Si 3 Door Rubbing Strip Removal
As yours is a three door I’m not familiar with the arrangement on the rear quarter panel . On the 400 and 200 5 door there is a little piece of trim on the edge of the wheel arch. I did replace this many years ago. If my memory is right there is a plastic insert in the bodywork and the trim piece ha...
by Plodder
Wed Jun 17, 2026 11:46 am
Yes rustproofing is my final job. I have replaced the electric window mechanism , the door handle and the rubbing strip plus a new membrane . The door handle and rubbing strip were better condition than the ones on it ( look like new ) although there is a difference in the shade of both items. Hence...
by Plodder
Tue Jun 16, 2026 8:54 pm
Just done this on my car . The best way is to remove the door card and the membrane . The rubbing strip can then be removed by removing the single screw and compressing the other plastic clips with a socket. I think if you pull the rubbing strip from the outside you may break the rubbing strip where...
