Search found 19 matches
- Sun Mar 02, 2025 3:24 pm
- Topic: Tailgate Harness YMN000810
Re: Tailgate Harness YMN000810
Hi there, thanks for the advice yes your right I'll do just that, thanks again
- Thu Feb 27, 2025 7:49 am
Hi montegoman, thanks for the reply, yes I've managed to repair the existing harness but I thought it would be a good idea to get a spare one incase of a second failure, I suppose a trudge around some salvage yards is the answer. I wonder who's got the original harness drawings issued to the OEM sup...
- Wed Feb 26, 2025 8:36 pm
Hello out there, late 2004 Rover 25 facelift, can anyone tell me where I can get a replacement tailgate harness either second hand or new there seems to be a total lack of this item anywhere. Any help would be very much appreciated, thanks
- Tue Jun 28, 2022 11:54 am
- Topic: Slight facia damage
Slight facia damage
Hi, I've got a facelift Rover 25 54 plate & the facia has some of the non reflective matt black coating missing which has revealed a shiny plastic base material, has anyone encountered this before if so how did you re touch the damaged areas & if you managed it using what type of material. F...
- Thu Nov 14, 2019 9:26 pm
- Topic: Throttle body change to 52mm
Re: Throttle body change to 52mm
Hi Cromp85, Thanks for the the reply & info I'll check it out, the car is a late facelift 25 so uncertain what size the current TB is.
Regards.
Regards.
- Tue Nov 12, 2019 5:52 pm
Hi there anybody know if when the TB is changed if the accelerator cable has to be changed at the same time, the vehicle is 1.4 16 valve Rover 25 facelift 54 plate.
Any assistance would be welcomed.
- Mon Aug 19, 2019 12:22 pm
- Topic: 54 plate Rover 25 facelift, heater only blowing cold air
Re: 54 plate Rover 25 facelift, heater only blowing cold air
Hi Vinny1979 & JOHNDQ, Just a quick update, I received the new Ranco valve on Saturday PM from Saabits of Newton Abbot cost £20 managed to fit it on Sunday afternoon dodging the showers & now the heater works fine. The replacment of the water pump, thermostat, manifold gasket & cambelt w...
- Thu Aug 15, 2019 8:14 am
Hi JohnDQ, I have a SAAB valve in transit right now when it arrives all the bits can be fitted at the same time.
Thanks for your reply.
- Wed Aug 14, 2019 4:02 pm
Thanks Vinny, I will have the cam belt changed, in fact the pump & thermostat can be changed at the same time along with the gasket you mention might as well get it all done in one go.
Thanks for the prompt response & the sound advice.
- Wed Aug 14, 2019 2:53 pm
With antifreeze in the system at the moment do you think I could put the flush into a the system or empty & refill adding the flush to clear water rather than mixing the two elements?
