Search found 60 matches
- Mon Dec 12, 2022 3:28 pm
- Topic: Coolant Temperature Sensor when unplugged does not activate fans
Re: Coolant Temperature Sensor when unplugged does not activate fans
I think the sender makes the circuit when the coolant gets too hot, which activates the fans, so disconnecting it leaves them switched off.
- Sun Oct 16, 2022 11:26 am
- Topic: 45 L Series starter Motor removal
Re: 45 L Series starter Motor removal
Slept on it & now sorted. New motor fitted & lot faster crank speed .
- Sat Oct 15, 2022 6:22 pm
I am struggling to locate the bottom fixing to get the starter motor off my 45 diesel , I have tried a small mirror but still having trouble , Is it a bolt into the threaded hole and which end is it located . Has anyone a pic or could advise?
Thanks Derek
Thanks Derek
- Tue Feb 22, 2022 6:52 pm
- Topic: Sill finisher removal
Re: Sill finisher removal
The finisher Slid off, no trouble at all . Thanks for info. and I didn't even need to remove rear wheel
- Sat Feb 19, 2022 5:32 pm
Thanks, I will try that when the rain clears.
- Thu Feb 17, 2022 1:25 pm
Can anyone advise how to remove the plastic sill finisher on my Rover 45. I have removed the 7 plastic fixings along the bottom. Does it now just pull sideways to remove? Had a search on Forum but cannot find any mention . Thanks
- Thu Dec 23, 2021 1:24 pm
- Topic: Was the Meastro built under licence in Bulgaria
Re: Was the Meastro built under licence in Bulgaria
I had a Ledbury built one for a while. Had an interesting specification, very much a pick & mix job!
- Tue Oct 19, 2021 2:53 pm
- Topic: Rover 45 headlining removal?
- Tue Oct 19, 2021 8:12 am
Have looked at various threads but cannot find an answer . How does one get the headlining out of a Saloon to recover it? Thanks in anticipation.
- Mon Sep 27, 2021 4:48 pm
- Topic: Brake issues
Re: Brake issues
Is the light still flickering now the calliper appears to be sticking ? Just wondering if its a pad wear sensor , if 99MY have them.
