Search found 818 matches
- Mon Aug 17, 2026 8:50 am
- Topic: Window Alignment
Re: Window Alignment
It sounds like there’s a tight spot in the new seal, together with possibly a weak/distorted window regulator (the “popping out” thing is typical of what happens when they start to bend - they’re rubbish!). It might be worth removing & refitting the seal to check the alignment/fitting in the cha...
- Sun Aug 16, 2026 7:38 pm
- Forum: Introductions
- Topic: New Streetwise
Re: New Streetwise
That wiring harness looks a mess! Hopefully cutting out the prior repairs and extending the harness with some new wiring & proper soldered repairs will do the job. As Duncan says, the new fob issue is easy enough to sort with the correct diagnostic gear - Richard via the Coupe club usually atten...
- Mon Jun 22, 2026 10:57 am
- Forum: Events and Meetings
- Topic: BMC & Leyland Day, Gaydon - Sunday 12th July 2026
Re: BMC & Leyland Day, Gaydon - Sunday 12th July 2026
Received mine this morning, thanks John!
- Fri Jun 19, 2026 12:27 pm
- Topic: Rimmers Part Drawing Removal
Re: Rimmers Part Drawing Removal
I’ve got the original parts microfiches if anyone needs help with a part number.
- Sun May 24, 2026 8:21 pm
- Topic: New Owner Rover 214Si 1994
Re: New Owner Rover 214Si 1994
Looks in excellent order!
In the Members Area you will be able to download the Rover technical manuals which will detail how to renew the cam belt, complete with torque settings.
- Sun Apr 12, 2026 10:21 pm
- Topic: Rover 200 R3 Aerial Water Leak
Re: Rover 200 R3 Aerial Water Leak
I've not experienced it on an R3, but it was a common customer complaint on the Citroen C1 when I was at a Citroen dealership. Ensuring the seal hadn't been flattened/crushed, plus renewing it together with a bead of sealant and ensuring the surrounding bodywork was clean & dry before fitting up...
- Sat Apr 04, 2026 9:26 am
- Topic: 🏁 Pride of Longbridge 2026 – Who’s Going? 🏁
Re: 🏁 Pride of Longbridge 2026 – Who’s Going? 🏁
As long as the weather plays ball I'll be along - will bring the 214 this time.
- Mon Mar 30, 2026 11:05 am
- Topic: Headliner - Replacing scrimfoam but retaining material
Re: Headliner - Replacing scrimfoam but retaining material
Thanks Iain. Would that be for them to do the job or for them to supply the material? They’d obviously prefer to do the job as the labour element is where the money is (understandably). Allon White will probably be a lower cost than DTT. Material can be sourced from Martrim, if you wanted to just g...
- Mon Mar 30, 2026 7:44 am
Duncan, go and speak to Allon White in Cranfield, or Dave The Trimmer nearby. They’ll be able to match up from sample swatches.
- Wed Mar 25, 2026 7:37 pm
- Topic: Pride of Longbridge 2026
Is there any info etc. on a club area for this?
