Just had a look at the e-book that John posted the link to regarding his restoration of his 216Gti.
This is a very impressive and comprehensive.
A lot better then shoving all the old MOT's etc into a folder. Well worth a look.
Search found 89 matches
- Wed Oct 11, 2023 10:00 am
- Forum: Introductions
- Topic: Restoring a Rover 200
- Fri Jun 23, 2023 9:39 am
- Topic: Window regulators - doing it neatly!
Re: Window regulators - doing it neatly!
Wow. Used the technique as described and it worked a treat. Can't understand why I didn't think of this myself. A much cleaner outcome.
- Thu Jun 22, 2023 2:37 pm
I have just been doing this myself.
Never thought of using a heat gun to remove the factory applied adhesive. Would of saved a lot of wasted time and mess!!!
- Sat Mar 11, 2023 4:31 pm
- Forum: Project Cars
- Topic: It's finally home after a bit of restoration
Re: It's finally home after a bit of restoration
Nice work. Like the photos showing the extent of the rust.
I have a similar 1997, 5 door Civic 1.5Lsi rotting on my drive. Has gone in similar areas, rear arches and rear sills etc.
I still give it a wash every so often. One day it will receive some attention.
- Mon Feb 27, 2023 6:17 pm
- Forum: Was It You?
- Topic: 216SLi by Hartshead Moor Services M62
Re: 216SLi by Hartshead Moor Services M62
Wow. What's the chance of that happening again
- Thu Dec 29, 2022 11:29 am
- Topic: Touching Up a Rover/Model Boot Badge
Re: Touching Up a Rover/Model Boot Badge
It's not like them to send sub-standard parts. You pay the high prices and expect "new" parts.
Definitely get on the phone and get a replacement.
- Thu Dec 22, 2022 12:22 pm
- Forum: The Lounge
- Topic: My wife’s and my little business
Re: My wife’s and my little business
Ingenious. Good luck with it
- Tue Dec 06, 2022 7:53 pm
- Topic: Removing locking wheel nuts
- Fri Dec 02, 2022 11:20 am
- Topic: Battery
Re: Battery
I have used a device called a CTEX MXS 5.0 battery charger/battery conditioner on my cars for several years. This device can be permanently connected to the battery via a "nifty" waterproof connection or use the supplied crocodile clips. It will maintain the battery through periods of inac...
- Wed Aug 03, 2022 6:28 pm
- Topic: Cleaning the dash rubber mat
Re: Cleaning the dash rubber mat
As Stan suggested and something I have used in the past. Black shoe polish (the type in the metal container) is great for getting a nice sheen on various rubber and black plastic parts.
