I've just found my sequence of pictures for rebuilding the box 32 pics
if this site has its own picture host ,...I can upload them with directions
all the best.mark
Search found 6 matches
- Wed Feb 19, 2020 9:45 pm
- Topic: Gearbox advice 220 turbo
- Sat Feb 08, 2020 8:53 pm
- Forum: Introductions
- Topic: hello everyone
Re: hello everyone
I sent you a PM a couple of days ago
all the best..mark
all the best..mark
- Sat Feb 08, 2020 8:34 pm
Re: Gearbox advice 220 turbo
Yes probably needs a rebuild . it will be the bearings the bearings are cheapo with plastic cages the plastic deteriorates and they wear out ... you need all new metal cage bearings for the rebuild - which are not rover parts you have to cross reference them to others I had a sequence of pictures on...
- Fri Feb 07, 2020 6:29 pm
- Topic: 420 Front suspension top arm wish bone -Warning
Re: 420 Front suspension top arm wish bone -Warning
Sorry , I'm not taking the wheel off , its too cold outside ....maybe when warms up
- Fri Feb 07, 2020 11:36 am
Had two sets of these in the past 4 years from two different manufacturers all had the same fault when new They had one captured metalastic bush and one that was free to swing on the bolt This is as far as I know not how they are meant to be - they will wear out quickly , trashing bolts and leading ...
- Thu Feb 06, 2020 8:12 pm
hello everyone
Mark here, you may or not remember me, rover with LPG conversion from rovertech (Disappeared don't know what happened) ..and the other site that seems to be not as good any more. Anyway ...did not know this site was up and running I was searching for a inlet cam cover for a 420 bubble, and had no lu...
